Renamed files within FCP and now getting lowres?
Rick Peters
on Mar 28, 2016 at 6:55:18 pm
I'm working on a large multicamera project, multiple files from each camera. I imported everything and waited for FCP to generate proxy and optimized media.
When I started creating the multiclips I got the brilliant (stupid) idea to rename them all to keep it better organized, which I did within FCP in the library list of files. (This edited the metadata apparently).
Everything is working, nothing is coming up as missing, I created the multiclip but when I got to export the master file I get a 1920x1080 clip that looks lowres, as if it is using the proxy media to render the high-res file.
I assume this is happening because I renamed the clips. An earlier quick rough cut done before I renamed the files yielded a nice high-res multiclip.
Is there a way to relink or otherwise save myself from starting from scratch?
Thanks for any assistance!
