How to duplicate a blu ray?
Jonny Cates
on Mar 27, 2016 at 8:48:50 pm
Using Disk Utility, I use to make multiple copies of my video DVD productions for clients. In El Capitan, this function has been taken away? Is this true?
How do you make a copies of productions for clients? Normally I just make an image of the file, and burn it whenever I need a copy.
Is there no way Disc Utility can do this any longer?
Thanks....
Jonny Cates
Jeff Kirkland
Re: How to duplicate a blu ray?
on Mar 27, 2016 at 9:39:12 pm
i always use Toast to burn images for clients as I prefer the error checking but I believe that the burn function from disk utility has been moved to the Finder in El Capitan. I'm on my iPad right now but from memory, right click on the image file and choose burn image.
If my memory's not what it should be a quick Google search should poijt you in the right direction.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Jonny Cates
on Mar 28, 2016 at 1:32:07 am
Well, Jeff... I'm a little confused. I can create a disc image -- but I can't burn a disc with Disc Utility. Even though my new iMac has no drive in it, an external burner won't burn from a DMG file.
I did find this:
http://www.computerworld.com/article/2995962/mac-apps/6-disk-utility-change...
"But wonder why Apple would continue letting you create a DMG file, but take away any burning capability?
thanks
Jonny Cates
Jeff Kirkland
on Mar 28, 2016 at 5:52:07 am
The burn image operation has moved. You use Disk Utility to create the image, but you use the Finder to burn the image.
http://osxdaily.com/2015/11/22/burn-disc-images-os-x-finder/
Jonny Cates
on Mar 28, 2016 at 6:05:10 am
Thank you Jeff!
Jonny Cates
