Audio fluctuated during multicam switching on the original footage
Sam Lee
on Mar 25, 2016 at 11:03:07 pm
I'm noticing a very annoying problem/bug in the latest ver of FCP 10:
The audio would fluctuate whenever I switch the angle. It occurred with 2, 3, 5 angles. This only occurs when the sound recorded into the camera. You can clearly hear it during quieter interview segment. This doesn't occur when I have a separate audio recorder .WAV file.
A closer analysis revealed that I have the background noise and hum filter applied globally. Hmm. When I uncheck those filters, it's no longer there. So something's not right with these filters.
David Powell
Re: Audio fluctuated during multicam switching on the original footage
on Mar 30, 2016 at 3:11:25 am
You can't do audio filters in the nest or you'll get noise at every cut on your timeline. You can only do video level corrections in the nest without interruptions.
