In and Out points?
Jonny Cates
In and Out points?
on Mar 24, 2016 at 6:33:57 am
Quick question:
When you have a finished project and are ready to send it to compressor, can you just use the "I" key and the "O" key to set the range of the project, same as an in and out point? Or do you have to use the range selection tool?
thanks
Jonny Cates
John Rofrano
Re: In and Out points?
on Mar 24, 2016 at 11:53:21 pm
[Jonny Cates] "When you have a finished project and are ready to send it to compressor, can you just use the "I" key and the "O" key to set the range of the project, same as an in and out point? Or do you have to use the range selection tool?"
Yes, you can use the "I" and "O" key to set the range (no need to use the range selection tool) and it will send the entire project to Compressor with the In and Out point set the same way in Compressor. This allows you to actually re-adjust the in and out point after you have sent the project to Compressor.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Jonny Cates
on Mar 25, 2016 at 3:19:58 am
Thanks John!
Jonny Cates
John Rofrano
on Mar 25, 2016 at 3:21:01 pm
You're welcome. Glad I could help.
~jr
