FCP X 10.2.3 backwards compatibe with 10.2.2?
Mark Hayes
on Mar 23, 2016 at 9:47:00 pm
I was installing a the new Apple security update and accidentally updated FCP X from 10.2.2 to 10.2.3. I am working on a large project with others who are using 10.2.2. Will this wreak havoc with the others. We are sharing transfer libraries etc.
If I need to re install 10.2.2 is there an easy way? I do have a Time Machine backup that is quite old but it would work if there is no other way. 10.2.3 seems like an incremental backup and maybe it doesn't make a difference and in fact is backward compatible to 10.2.2.
If I have to reinstall 10.2.2 is there a link I can use so I don't have to do a time machine restore and lose lots of other stuff I have installed?
Thanks for any help.
Mark
Mark Hayes
Jeremy Garchow
Re: FCP X 10.2.3 backwards compatibe with 10.2.2?
on Mar 23, 2016 at 10:19:21 pm
Just drag the 10.2.2 app out of your time machine backup and add it to the Applications folder (replacing 10.2.3).
I do think they are backwards compatible.
Mark Hayes
on Mar 23, 2016 at 10:34:43 pm
Thanks. Will try it.
Mark Hayes
Noah Kadner
on Mar 24, 2016 at 2:09:55 am
Can't see a reason why you'd want/need to downgrade but the Project format wasn't updated so it kinda doesn't matter either.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
