Finalcut X 10.2.3 Crashing on 720p share
Robert Rinkewich
on Mar 12, 2016 at 3:42:40 pm
I recently upgrade to 10.2.3 on my 13 inch macbook pro. At first I thought it was a problem with the upgrade process, but I also recently purchased a new 2014 model MacBook Pro 15 and I'm having the same issue with a new install. The 13 inch is i7, 3.1, 16gb ram, 512gb, and the 15inch is i7, 2.5, 16gb, 512gb.
I have an event where I have to output over 300 one to three minute 720p files. In the past I was able to share many of them, probably around 20 to 30 files, and then come back later after they rendered out. I'm having an issue where Final Cut crashes every once in a while after I output several share's at 720p. When it crashes, I lose all the remaining ones that I shared, and I have to output them again.
Anyone having this issue? It's becoming a pain, because I have to crank these out quickly, and I'm stuck sharing a couple at a time and waiting for them to finish.
Thank you
Robert Rinkewich
Andy Neil
Re: Finalcut X 10.2.3 Crashing on 720p share
on Mar 12, 2016 at 4:33:05 pm
When you say you're sharing a couple at a time, what exactly do you mean? There's no batch export in FCPX so are you just exporting one, then exporting the next while it's working on the first? Also, did you create a special share setting or are you using a default FCPX share? Do you have Compressor? If so, are you using a compressor setting or can you try with a compressor setting?
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Robert Rinkewich
on Mar 12, 2016 at 4:40:04 pm
Andy,
Right after posting, I got another crash and I had only shared two files 1 minute each, I'll post the info from it below.
Yes, I'm just sharing one after another. With other versions of Finalcut Pro X I was able to just keep sending one share after another, and they would stack up in the Background Task window under "share". This is the 3rd year I've done this job, same computer, only difference is the program version.
I have compressor, but I haven't tried that yet, I've just been using the share in Finalcut for 720p.
Heres the error:
Process: Final Cut Pro [459]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCut
Version: 10.2.3 (276640)
Build Info: ProEditor-27664000056000000~1
App Item ID: 424389933
App External ID: 815823966
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Final Cut Pro [459]
User ID: 501
Date/Time: 2016-03-12 10:59:38.305 -0500
OS Version: Mac OS X 10.11.3 (15D21)
Report Version: 11
Anonymous UUID: 6ADCE84A-58D6-CDB2-1E4C-C1B5C028B2C7
Sleep/Wake UUID: 15BE5A3B-2BA4-44F9-9A0F-833E669F2A36
Time Awake Since Boot: 5700 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000018
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x18:
__TEXT 000000010a531000-000000010a610000 [ 892K] r-x/rwx SM=COW /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Application Specific Information:
objc_msgSend() selector name: retain
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x00007fff8cc654dd objc_msgSend + 29
1 com.apple.QuartzCore 0x00007fff8d353fe0 CAAnimation_setter(CAAnimation*, unsigned int, _CAValueType, void const*) + 117
2 com.apple.QuartzCore 0x00007fff8d35501d -[CAPropertyAnimation setKeyPath:] + 31
3 com.apple.QuartzCore 0x00007fff8d358ccd +[CAPropertyAnimation animationWithKeyPath:] + 62
4 com.apple.FinalCut 0x000000010a59a27a -[PEMeterLayer layoutSublayers] + 3082
5 com.apple.QuartzCore 0x00007fff8d33f904 CA::Layer::layout_if_needed(CA::Transaction*) + 366
6 com.apple.QuartzCore 0x00007fff8d33f782 CA::Layer::layout_and_display_if_needed(CA::Transaction*) + 24
7 com.apple.QuartzCore 0x00007fff8d33ecf1 CA::Context::commit_transaction(CA::Transaction*) + 277
8 com.apple.QuartzCore 0x00007fff8d33ea24 CA::Transaction::commit() + 508
9 com.apple.QuartzCore 0x00007fff8d34d917 CA::Transaction::observer_callback(__CFRunLoopObserver*, unsigned long, void*) + 71
10 com.apple.CoreFoundation 0x00007fff999ebe37 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
11 com.apple.CoreFoundation 0x00007fff999ebda7 __CFRunLoopDoObservers + 391
12 com.apple.CoreFoundation 0x00007fff999dd358 CFRunLoopRunSpecific + 328
13 com.apple.HIToolbox 0x00007fff98068935 RunCurrentEventLoopInMode + 235
14 com.apple.HIToolbox 0x00007fff9806876f ReceiveNextEventCommon + 432
15 com.apple.HIToolbox 0x00007fff980685af _BlockUntilNextEventMatchingListInModeWithFilter + 71
16 com.apple.AppKit 0x00007fff8be4f0ee _DPSNextEvent + 1067
17 com.apple.AppKit 0x00007fff8c21b943 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
18 com.apple.AppKit 0x00007fff8be44fc8 -[NSApplication run] + 682
19 com.apple.prokit 0x000000010a98842f NSProApplicationMain + 329
20 com.apple.FinalCut 0x000000010a533bf0 main + 1344
21 libdyld.dylib 0x00007fff995315ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8bb60ff6 kevent_qos + 10
1 libdispatch.dylib 0x00007fff87790099 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff8778fd01 _dispatch_mgr_thread + 52
Thread 2:: com.apple.ProGL.object-deletion
0 libsystem_kernel.dylib 0x00007fff8bb5feb2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff88898150 _pthread_cond_wait + 767
2 com.apple.progl.framework 0x000000010ce5777f (anonymous namespace)::threadFunc(void*) + 71
3 com.apple.procore.framework 0x000000010a71de63 PCThread::startup(void*) + 29
4 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 3:: MIO Mounting Thread
1 libsystem_pthread.dylib 0x00007fff88898186 _pthread_cond_wait + 821
2 com.apple.Foundation 0x00007fff889187a2 -[NSCondition waitUntilDate:] + 348
3 com.apple.Foundation 0x00007fff88918601 -[NSConditionLock lockWhenCondition:beforeDate:] + 232
4 com.apple.proapps.MIO 0x000000010c915aac -[PluginLockPair scanPaths] + 364
5 com.apple.Foundation 0x00007fff88a9cc6f __NSThread__start__ + 1351
6 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
8 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 4:: MIO Mounting Thread
Thread 5:: MIO Mounting Thread
Thread 6:: MIO Mounting Thread
Thread 7:: MIO Mounting Thread
Thread 8:: MIO Mounting Thread
Thread 9:: com.apple.dvdplayback-DDPTask
0 libsystem_kernel.dylib 0x00007fff8bb5a3c2 semaphore_wait_trap + 10
1 com.apple.AVCHDPlugin 0x000000014020fa17 semaphore_wait(viona_semaphore_t*) + 39
2 com.apple.AVCHDPlugin 0x000000014021b360 WinPortServer::ProcessMessages() + 128
3 com.apple.AVCHDPlugin 0x00000001401cb148 0x140169000 + 401736
4 com.apple.AVCHDPlugin 0x0000000140210012 ST20Thread::Run(PThreadRunParams*) + 34
5 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
Thread 10:: com.apple.helium-texture-finish
2 com.apple.Helium.HeliumRender 0x000000010e953eaa TextureDeleteQueue::threadLoop() + 202
3 com.apple.Helium.HeliumRender 0x000000010e953ccd textureFinishThread(void*) + 29
Thread 11:: com.apple.helium.rq.gpu-ru0.vs0
2 com.apple.Helium.HeliumRender 0x000000010e9a8bc3 HGSynchronizable::Wait() + 51
3 com.apple.Helium.HeliumRender 0x000000010e8f6b28 HGRenderQueue::GetRenderJob(HGRenderExecUnit*, HGRenderJob**) + 344
4 com.apple.Helium.HeliumRender 0x000000010e8ee0fa HGRenderExecUnit::RunLoop() + 234
5 com.apple.Helium.HeliumRender 0x000000010e8edffe StartRenderExecUnitFunc(void*) + 14
Thread 12:: com.apple.helium.rq.gpu-ru1.vs0
Thread 13:: com.apple.helium.rq.gpu-cu2.vs0
Thread 14:: com.apple.helium.rq.pbo-rbu0.vs0
3 com.apple.Helium.HeliumRender 0x000000010e8f8ec0 HGRenderQueue::GetPBOReadbackJob(HGPBOReadbackExecUnit*, HGPBOReadbackJob**) + 80
4 com.apple.Helium.HeliumRender 0x000000010e8ed56e HGPBOReadbackExecUnit::RunLoop() + 174
5 com.apple.Helium.HeliumRender 0x000000010e8ed4ae StartPBOExecUnitFunc(void*) + 14
Thread 15:: com.apple.helium.rq.pbo-rbu1.vs0
Thread 16:: com.apple.helium.rq.pbo-rbu2.vs0
Thread 17:: com.apple.flexo.player-render (playback)
4 com.apple.Flexo 0x000000010ad6445b -[FFPlayer _waitForAttention] + 43
5 com.apple.Flexo 0x000000010ad40460 -[FFPlayer playerRenderThreadMain:] + 208
6 com.apple.Foundation 0x00007fff88a9cc6f __NSThread__start__ + 1351
7 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 18:: com.apple.flexo.time-rate-change-controller
2 com.apple.Flexo 0x000000010ad3ea03 TimeRateChangeController::threadFunction() + 115
3 com.apple.Flexo 0x000000010ad658fc TimeRateChangeController::thread_routine(void*) + 60
Thread 19:: com.apple.flexo.worker-thread
1 com.apple.Flexo 0x000000010af6331b WorkerThread::Run() + 315
2 com.apple.Flexo 0x000000010aedccef Thread::RunHelper(void*) + 47
3 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
4 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
5 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 20:: CVDisplayLink
2 com.apple.CoreVideo 0x00007fff908270d8 CVDisplayLink::waitUntil(unsigned long long) + 232
3 com.apple.CoreVideo 0x00007fff90826ed1 CVDisplayLink::runIOThread() + 511
4 com.apple.CoreVideo 0x00007fff908269a9 startIOThread(void*) + 147
6 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 21:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff8bb5a386 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8bb597c7 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff999de624 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff999ddaec __CFRunLoopRun + 1356
4 com.apple.CoreFoundation 0x00007fff999dd338 CFRunLoopRunSpecific + 296
5 com.apple.AppKit 0x00007fff8bf0e065 _NSEventThread + 149
Thread 22:: com.apple.flexo.worker-thread
Thread 23:: com.apple.flexo.worker-thread
Thread 24:: com.apple.coremedia.scheduledfileio
2 com.apple.CoreMedia.ProAppsSupport 0x000000010a8b7f91 WaitOnCondition + 11
3 com.apple.CoreMedia.ProAppsSupport 0x000000010a8b7d9e FigSemaphoreWaitRelative + 156
4 com.apple.CoreMedia.ProAppsSupport 0x000000010a8ad788 FigScheduledFileIOThread + 141
5 com.apple.CoreMedia.ProAppsSupport 0x000000010a8b8a15 figThreadMain + 417
Thread 25:: com.apple.helium-unit
0 libsystem_kernel.dylib 0x00007fff8bb5fee2 __psynch_mutexwait + 10
1 libsystem_pthread.dylib 0x00007fff8889aa49 _pthread_mutex_lock_wait + 89
2 com.apple.Helium.HeliumRender 0x000000010e96b602 hg_pthread_loop(void*) + 114
Thread 26:: com.apple.helium-unit
Thread 27:: com.apple.helium-unit
Thread 28:: com.apple.helium-unit
Thread 29:: com.apple.helium-unit
Thread 30:: com.apple.helium-unit
Thread 31:: com.apple.CoreAnimation.CAOpenGLLayer
5 com.apple.CoreFoundation 0x00007fff99aa01f1 CFRunLoopRun + 97
6 com.apple.QuartzCore 0x00007fff8d4a6fb9 CAOpenGLLayer_render_thread(void*) + 152
7 com.apple.QuartzCore 0x00007fff8d350b39 thread_fun + 25
8 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 32:
6 com.apple.DiscRecording 0x00007fff96a3407e DRWorkLoop::WorkLoop() + 228
7 com.apple.DiscRecording 0x00007fff96a33f87 DRWorkLoop::WorkLoopEntry(DRWorkLoop*) + 9
8 com.apple.DiscRecording 0x00007fff96a33c99 DRThreadObject::StartRoutine(DRThreadObject*) + 125
9 com.apple.DiscRecording 0x00007fff96a33b2d DRThreadObject::SymbolRoutine(DRThreadObject*) + 9
10 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
11 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
12 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 33:: com.apple.flexo.worker-thread
Thread 34:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff8bb60176 __select + 10
1 com.apple.CoreFoundation 0x00007fff99a2a16a __CFSocketManager + 762
2 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 35:: com.apple.flexo.player-render (playback)
Thread 36:: com.apple.flexo.time-rate-change-controller
Thread 37:: com.apple.flexo.worker-thread
Thread 38:: Dispatch queue: com.apple.CompressorKit.CKImmedaiteBatchOperation :: NSOperation 0x7fd4b1619af0 (QOS: USER_INITIATED)
5 com.apple.Foundation 0x00007fff888ebf86 -[NSConcreteTask waitUntilExit] + 205
6 com.apple.CompressorKitMAS 0x000000015bdaf3c5 -[CKImmedaiteBatchOperation runTranscodeFor:] + 1521
7 com.apple.CoreFoundation 0x00007fff999a717c __invoking___ + 140
8 com.apple.CoreFoundation 0x00007fff999a6fce -[NSInvocation invoke] + 286
9 com.apple.Foundation 0x00007fff8896c168 -[NSInvocationOperation main] + 34
10 com.apple.Foundation 0x00007fff8891c2fb -[__NSOperationInternal _start:] + 654
11 com.apple.Foundation 0x00007fff8891bde7 __NSOQSchedule_f + 194
12 libdispatch.dylib 0x00007fff8778a33f _dispatch_client_callout + 8
13 libdispatch.dylib 0x00007fff8778ef6f _dispatch_queue_drain + 754
14 libdispatch.dylib 0x00007fff8779563b _dispatch_queue_invoke + 549
15 libdispatch.dylib 0x00007fff8778dc87 _dispatch_root_queue_drain + 538
16 libdispatch.dylib 0x00007fff8778da34 _dispatch_worker_thread3 + 91
17 libsystem_pthread.dylib 0x00007fff8889768f _pthread_wqthread + 1129
18 libsystem_pthread.dylib 0x00007fff88895365 start_wqthread + 13
Thread 39:: BGTask: FFBackgroundShareOperation Dispatch queue: NSOperationQueue 0x7fd4b163f250 :: NSOperation 0x7fd4b1622800 (QOS: USER_INITIATED)
4 com.apple.Flexo 0x000000010af5b140 -[FFBackgroundShareOperation performShareOperation:task:] + 208
5 com.apple.Flexo 0x000000010b76e36c FFApplicationHandleExceptionThatShouldNotBeIgnoredInBlock + 12
6 com.apple.Flexo 0x000000010ae96aad -[FFBackgroundTask main] + 333
7 com.apple.Foundation 0x00007fff8891c2fb -[__NSOperationInternal _start:] + 654
8 com.apple.Foundation 0x00007fff8891bde7 __NSOQSchedule_f + 194
9 libdispatch.dylib 0x00007fff8778a33f _dispatch_client_callout + 8
10 libdispatch.dylib 0x00007fff8778ef6f _dispatch_queue_drain + 754
11 libdispatch.dylib 0x00007fff8779563b _dispatch_queue_invoke + 549
12 libdispatch.dylib 0x00007fff8778dc87 _dispatch_root_queue_drain + 538
13 libdispatch.dylib 0x00007fff8778da34 _dispatch_worker_thread3 + 91
14 libsystem_pthread.dylib 0x00007fff8889768f _pthread_wqthread + 1129
15 libsystem_pthread.dylib 0x00007fff88895365 start_wqthread + 13
Thread 40:: com.apple.flexo.player-render (render)
3 com.apple.Flexo 0x000000010b18b357 -[FFPlayerScheduledData waitForFlattenedImagesBeforeDate:] + 87
4 com.apple.Flexo 0x000000010ad572a5 -[FFPlayer _renderVideo] + 8133
5 com.apple.Flexo 0x000000010ad598f4 -[FFPlayer idle] + 196
6 com.apple.Flexo 0x000000010ad404b5 -[FFPlayer playerRenderThreadMain:] + 293
7 com.apple.Foundation 0x00007fff88a9cc6f __NSThread__start__ + 1351
Thread 41:: com.apple.flexo.time-rate-change-controller
Thread 42:
4 com.apple.Flexo 0x000000010af5e12d -[FFDestProMSExporter copyFrameAtTime:waitUntilFound:] + 397
5 com.apple.Flexo 0x000000010b67094f -[ProMSMediaServer renderVideoFrame:] + 2111
6 com.apple.CompressorKitMAS 0x000000015bdb953c CKMediaServerRenderVideoFrameProc(void*, RenderVideoParams const*) + 60
7 com.apple.compressor.MediaServerAPI 0x000000015c25a513 CVideoMediaServerIPCHandler::handleMessage(MediaServerIPCParams&) + 211
8 com.apple.AECore 0x00000001158aee51 CPipeBasedIPCServer::beginMessageReceive() + 323
9 com.apple.compressor.MediaServerAPI 0x000000015c258d89 PluginReadyToRecieveRenderVideo + 145
10 com.apple.CompressorKitMAS 0x000000015bdb96f7 -[CKMediaServer renderLoop:] + 83
11 com.apple.Foundation 0x00007fff88a9cc6f __NSThread__start__ + 1351
12 libsystem_pthread.dylib 0x00007fff88897c13 _pthread_body + 131
13 libsystem_pthread.dylib 0x00007fff88897b90 _pthread_start + 168
14 libsystem_pthread.dylib 0x00007fff88895375 thread_start + 13
Thread 43:
0 libsystem_kernel.dylib 0x00007fff8bb606de __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff88897729 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff88895365 start_wqthread + 13
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55:
Thread 56:
Thread 57:
Thread 58:
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
Thread 65:
Thread 66:
Thread 67:
Thread 68:
Thread 69:
Thread 70:
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 77:
Thread 78:
0 libsystem_kernel.dylib 0x00007fff8bb5a3da semaphore_timedwait_trap + 10
1 libdispatch.dylib 0x00007fff87795b9b _dispatch_semaphore_wait_slow + 149
2 libdispatch.dylib 0x00007fff8778fc4f _dispatch_worker_thread + 148
Thread 79:
Thread 80:
Thread 81:
Thread 82:
Thread 83:
Thread 84:
Thread 85:
Thread 86:
Thread 87:
Thread 88:
Thread 89:
Thread 90:
Thread 91:
Thread 92:
Thread 93:
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:: com.apple.flexo.worker-thread
Thread 103:: com.apple.flexo.sequence-audio-stream-dynamic-scoper
1 com.apple.Flexo 0x000000010b7e9f0b FFAudioDynamicScopingWindow::Run() + 43
Thread 104:: CVDisplayLink
Thread 105:
2 com.apple.AppleGVAFramework 0x00007fff8426607f 0x7fff84228000 + 254079
3 com.apple.AppleGVAFramework 0x00007fff84265c41 0x7fff84228000 + 252993
Thread 106:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff8ee3a5ee HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3 com.apple.audio.CoreAudio 0x00007fff8ee3a57c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fff8ee38939 HALC_ProxyIOContext::IOWorkLoop() + 1149
5 com.apple.audio.CoreAudio 0x00007fff8ee383ee HALC_ProxyIOContext::IOThreadEntry(void*) + 88
6 com.apple.audio.CoreAudio 0x00007fff8ee382c3 HALB_IOThread::Entry(void*) + 75
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007fd4b11c23d0 rbx: 0x0000000000000000 rcx: 0x00007fd4b15352a0 rdx: 0x0000000000000008
rdi: 0x00007fd4b11c23d0 rsi: 0x00007fff99dceb7a rbp: 0x00007fff556cc9a0 rsp: 0x00007fff556cc908
r8: 0x00007fd4b1563a30 r9: 0x00007fd4b11e47f0 r10: 0x00007fff99dceb7a r11: 0x0000000000000000
r12: 0x00007fff556cc910 r13: 0x0000000000000002 r14: 0x00007fff755135a8 r15: 0x00007fff556cc910
rip: 0x00007fff8cc654dd rfl: 0x0000000000010246 cr2: 0x0000000000000018
Logical CPU: 4
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x10a531000 - 0x10a60fff7 com.apple.FinalCut (10.2.3 - 276640) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0x10a6af000 - 0x10a6defff com.apple.iTunesLibrary (12.3.2 - 12.3.2.35) /Library/Frameworks/iTunesLibrary.framework/Versions/A/iTunesLibrary
0x10a6fa000 - 0x10a80afff com.apple.procore.framework (4.0.2 - 27289.8.56) /Applications/Final Cut Pro.app/Contents/Frameworks/ProCore.framework/Versions/A/ProCore
0x10a885000 - 0x10a91bffb com.apple.CoreMedia.ProAppsSupport (1.0 - 1562.19.1) <9925F68C-66F7-3BDD-97A1-17FAC9D8FAD7> /Applications/Final Cut Pro.app/Contents/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x10a96c000 - 0x10ab71ff7 com.apple.prokit (8.0 - 5061) <84F19C7C-BBA0-3704-9F18-EFD83A76EB3E> /Applications/Final Cut Pro.app/Contents/Frameworks/ProKit.framework/Versions/A/ProKit
0x10acf0000 - 0x10c081fef com.apple.Flexo (1.0.0 - 27522.1.56) <5016EE74-99F6-31BA-A5CA-313F13DDCD35> /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Flexo
0x10c8e5000 - 0x10c9b5ff7 com.apple.proapps.MIO (2.0 - 27312.0.56) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x10ca2d000 - 0x10ca7eff7 com.apple.pro.sharedstudio (1.0 - 27414.8.56) <85B74AA1-156C-33E1-8ADE-DE981F7802F7> /Applications/Final Cut Pro.app/Contents/Frameworks/StudioSharedResources.framework/Versions/A/StudioSharedResources
0x10cadd000 - 0x10cc57ff7 com.apple.TLKit (1.0 - 27289.8.56) <3FD38C9C-0BC1-3631-879C-3CB65A5F13A1> /Applications/Final Cut Pro.app/Contents/Frameworks/TLKit.framework/Versions/A/TLKit
0x10cd12000 - 0x10cdb6fff com.apple.LunaKit (1.0 - 27414.8.56) <8884BE14-DC37-384A-A761-32BED04A64B4> /Applications/Final Cut Pro.app/Contents/Frameworks/LunaKit.framework/Versions/A/LunaKit
0x10ce4c000 - 0x10ce87fff com.apple.progl.framework (1.0 - 27289.8.56) /Applications/Final Cut Pro.app/Contents/Frameworks/ProGL.framework/Versions/A/ProGL
0x10cec0000 - 0x10cfdafef com.apple.ProAppsFxSupport (4.0.0 - 27289.8.56) <08F68FD4-6F41-32FC-AE2B-05F615161A73> /Applications/Final Cut Pro.app/Contents/Frameworks/ProAppsFxSupport.framework/Versions/A/ProAppsFxSupport
0x10d237000 - 0x10d37afff com.apple.prochannel.framework (4.0.2 - 27361.3.56) <3F5C1173-6E16-3EFA-8FCF-F23DADA1008A> /Applications/Final Cut Pro.app/Contents/Frameworks/ProChannel.framework/Versions/A/ProChannel
0x10d483000 - 0x10d4a3fff com.apple.DeepSkyLite (0.6 - 27373.4.56) /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/DeepSkyLite.framework/Versions/A/DeepSkyLite
0x10d4be000 - 0x10d823ff3 com.apple.VideoToolbox.ProAppsSupport (1.0 - 1562.19.1) /Applications/Final Cut Pro.app/Contents/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x10d86d000 - 0x10dd59fff com.apple.MediaToolbox.ProAppsSupport (1.0 - 1562.19.1) /Applications/Final Cut Pro.app/Contents/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x10de29000 - 0x10de29fff com.apple.Helium (3.1.0 - 27493.6.56) <335CBB8C-D7AF-37E1-807A-A676CAFF5479> /Applications/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Helium
0x10de30000 - 0x10dea5fff com.apple.proinspector.framework (4.0.2 - 27289.8.56) <86E1784D-63D0-3930-8D39-E4799D25A1C1> /Applications/Final Cut Pro.app/Contents/Frameworks/ProInspector.framework/Versions/A/ProInspector
0x10df06000 - 0x10df4dfff com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <14F0B230-CA35-3D7D-A0B1-437BF4120290> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x10df8e000 - 0x10dfeafff com.apple.proshapes.framework (1.0 - 27289.8.56) <93663468-FF33-3425-8FB9-4D32D5036740> /Applications/Final Cut Pro.app/Contents/Frameworks/ProShapes.framework/Versions/A/ProShapes
0x10e030000 - 0x10e13dfff com.apple.proosc.framework (3.1.0 - 27312.0.56) /Applications/Final Cut Pro.app/Contents/Frameworks/ProOSC.framework/Versions/A/ProOSC
0x10e1a9000 - 0x10e5d8ff7 com.apple.vision.FaceCoreEmbedded (3.2.2 - 3.2.2) /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/FaceCoreEmbedded.framework/Versions/A/FaceCoreEmbedded
0x10e7f7000 - 0x10e86cff7 com.apple.procurveeditor.framework (3.1.0 - 27289.8.56) /Applications/Final Cut Pro.app/Contents/Frameworks/ProCurveEditor.framework/Versions/A/ProCurveEditor
0x10e8b5000 - 0x10e8c8fff com.apple.TLKEventDispatcher (1.0 - 27289.8.56) /Applications/Final Cut Pro.app/Contents/Frameworks/TLKEventDispatcher.framework/Versions/A/TLKEventDispatcher
0x10e8db000 - 0x10ebe6ff7 com.apple.Helium.HeliumRender (2.1.0 - 27493.6.56) <9FD92796-B50D-3E12-9083-3A2524611FE7> /Applications/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0x10ecb0000 - 0x10ed91fff com.apple.Helium.Heliumfilters (2.1.0 - 27493.6.56) <48D02442-FC6F-3CD7-B7F1-07D57DBE911C> /Applications/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumFilters.framework/Versions/A/HeliumFilters
0x10f0f5000 - 0x10f36ffff com.apple.Helium.HeliumSensoCore (2.0.2 - 27493.6.56) <66493E77-C3C5-3598-93D5-447D6AB375A3> /Applications/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumSensoCore.framework/Versions/A/HeliumSensoCore
0x10f3ef000 - 0x10f3f2ff7 com.apple.Helium.HeliumSenso (2.0.2 - 27493.6.56) /Applications/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumSenso.framework/Versions/A/HeliumSenso
0x10f402000 - 0x10f402fe7 +cl_kernels (???) cl_kernels
0x10f405000 - 0x10f542fef com.apple.mobiledevice (823.10.3 - 823.10.3) <1DD0B2D9-8E99-3411-BC29-993822BD4A4A> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x10f5cc000 - 0x10f603fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <4A755EA1-3CF5-32A6-8939-8D2998577406> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10f62e000 - 0x10f73dfff com.apple.AudioVideoBridging (403.4 - 403.4) <8AAB1A21-CA30-3B77-BD3B-8F3544BB098F> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x10f7f2000 - 0x10f80bfff libexpat.1.dylib (12.20.1) /usr/lib/libexpat.1.dylib
0x10f819000 - 0x10f81ffff com.apple.TimeSync (1.0 - 403.4) <4E3FCB52-7F47-39A2-9C29-11CFE4823CC4> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x10f82d000 - 0x10f858ff7 com.apple.FWAVC (501.47 - 47) <32CDC262-F59A-3947-814D-CFF519B2E15E> /System/Library/PrivateFrameworks/FWAVC.framework/Versions/A/FWAVC
0x10f877000 - 0x10f889ff7 com.apple.PluginManager (1.7.4 - 27289.8.56) <0FDFC837-71FE-3805-8F61-D68BCB7733A9> /Applications/Final Cut Pro.app/Contents/Frameworks/PluginManager.framework/Versions/B/PluginManager
0x10f89c000 - 0x10f8b6ff7 com.apple.fxplugframework (3.1 - 27312.0.56) /Applications/Final Cut Pro.app/Contents/Frameworks/FxPlug.framework/Versions/A/FxPlug
0x10fd51000 - 0x10fd9eff3 com.apple.CoreMediaIO.FCPX.Lion (601.0 - 4761) <01FC369E-BDD9-387B-931B-363358683773> /Applications/Final Cut Pro.app/Contents/Frameworks/CoreMediaIO.framework/Versions/Current/CoreMediaIO
0x112711000 - 0x112c69ff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.12.13 - 10.1.2) /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x114e49000 - 0x114e6aff7 com.apple.QuartzComposer.ExtraPatches (4.1 - 334) <0D91F242-D3F8-3FD6-A6BF-7F368976D29A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/Resources/ExtraPatches.plugin/Contents/MacOS/ExtraPatches
0x114e7f000 - 0x114f51ffb com.apple.PubSub (1.0.5 - 65.40) <015C0A30-1F6F-3D62-810E-71A5C637CDC8> /System/Library/Frameworks/PubSub.framework/Versions/A/PubSub
0x114fbc000 - 0x114fe2ff7 com.apple.audio.OpenAL (1.8 - 1.8) <1513F0E8-B22A-3442-A205-A78517F9BBBA> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x114ff5000 - 0x114ffefff com.apple.Audio.provider (1.0.0 - 27522.1.56) <606991F3-AD9E-30BC-901C-0F383A2E6CB4> /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/MediaProviders/AudioProvider.fxp/Contents/MacOS/AudioProvider
0x11500a000 - 0x11506afe7 com.apple.proapps.AppleAVCIntraCodec (1.2.2 - 8559.55) /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleAVCIntraCodec.bundle/Contents/MacOS/AppleAVCIntraCodec
0x115078000 - 0x115084ff7 com.apple.proapps.AppleAVCLGCodecEmbedded (1.0.3 - 8558.55) <6E1E596F-64CE-383A-AB07-4D14B37728B5> /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleAVCLGCodecEmbedded.bundle/Contents/MacOS/AppleAVCLGCodecEmbedded
0x11508e000 - 0x115291fcf +com.mainconcept.mc.bc.dec.avc (9.9 - 9.9.11.9554) <6A73E7D7-8C62-D2A9-A323-776C795A066F> /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Codecs/AppleAVCLGCodecEmbedded.bundle/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/9/mc_bc_dec_avc
0x11529f000 - 0x1155a3fee +com.mainconcept.mc.enc.avc (9.11 - 9.11.13.8866) /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Codecs/AppleAVCLGCodecEmbedded.bundle/Contents/Frameworks/mc_enc_avc.framework/Versions/9/mc_enc_avc
0x1155e3000 - 0x115633fff com.apple.proapps.AppleDVCPROHDCodec (1.0.2 - 8376.55) <90FB70B0-0160-3ED4-B309-E2237DDA156D> /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleDVCPROHDCodec.bundle/Contents/MacOS/AppleDVCPROHDCodec
0x115640000 - 0x115665fff com.apple.proapps.AppleIMXCodec (1.0.2 - 8376.55) <1EB784DE-2B5C-3274-85A1-5C85F7C89A4E> /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleIMXCodec.bundle/Contents/MacOS/AppleIMXCodec
0x115670000 - 0x1156b3fff com.apple.proapps.AppleIntermediateCodec (1.0.2 - 8376.55) <075F2331-9396-363A-BEB5-8E02C934790D> /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleIntermediateCodec.bundle/Contents/MacOS/AppleIntermediateCodec
0x1156bf000 - 0x115747ff7 com.apple.proapps.AppleMPEG2Codec (1.0.5 - 6472.33) /Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleMPEG2Codec.bundle/Contents/MacOS/AppleMPEG
Andy Neil
on Mar 12, 2016 at 4:58:31 pm
When posting crash threads, please do not post the ENTIRE crash thread. It's not necessary and it janks up the website formatting. At the top of the crash report, it'll tell you which thread crashed:
[Robert Rinkewich] "Crashed Thread: 0 Dispatch queue: com.apple.main-thread"
And then you just need to post the actual thread that crashed:
[Robert Rinkewich] "Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
21 libdyld.dylib 0x00007fff995315ad start + 1"
It's much cleaner. But in reality, very few of us understand crash threads at all. Maybe you'll get lucky but I can't tell what's happening with your computer. On the surface it sounds like some kind of memory issue. But again, I don't read crash threads or understand them.
I would try creating an identical compressor setting for 720p (which codec are you using: pro res or H264?) and share via that to see if the crashes go away.
Andy
Joe Marler
on Mar 12, 2016 at 7:56:16 pm
[Robert Rinkewich] "I got another crash and I had only shared two files 1 minute each"
The fact it crashed when sharing only two small files is suspicious. What camera and codec are you using, and does your project contain any 3rd party plugins? If 3rd party plugins, can you temporarily remove those on a few clips and try to export without them?
Another standard FCPX troubleshooting procedure is to reset your preferences. This this article for more info: https://support.apple.com/en-us/HT203477
I saw a recommendation to check your fonts when experiencing problems like this. The procedure is:
Font Book > All Fonts > select ALL File menu > Validate Fonts. Any hint of a problem, deactivate or remove the font. I don't have any direct experience with this, just passing it along.
Robert Rinkewich
on Mar 12, 2016 at 9:09:53 pm
Joe,
Its doing it on two Macbook Pro's. My old one and new one. The new one has a fresh install, actually it was the first and only program I installed after taking it out of the box. No plugins, fonts, etc. Its straight video to an 720p mv4
Been using the same camera for 4 years doing this event 3 times a year. This is the first time I'm getting crashes right after 10.2.3 came out. Last year I was able to output 30 files and walk away and come back and they are done. Never had a crash.
I'm using a Sony Nx5u AVCHD.
Joe Marler
on Mar 13, 2016 at 2:54:33 pm
Obviously it should not be crashing. It's good to look at the stack trace but it's often of limited benefit without source code access. That is a common camera and codec so nothing unique there.
Are these 300 clips each in a separate project or are they sparse selected clips from a big timeline? Can you describe in more detail the exact sharing procedure, and what export parameters you're using?
Is it reproducible in any way or is it random? E.g, when it crashed when sharing only two files, if you re-try that will it always crash on those? What if you re-try those two files 5 or 10 times?
Can you pre-render the entire timeline(s) before sharing sharing those? Sharing (exporting) is actually two discrete phases: rendering then exporting (ie encoding). Knowing whether it crashes in the rendering phase vs encoding phase could be useful.
In software support, anything which has a tidy replication scenario tends to get fixed quickly. Also efforts to narrow narrow down the scenario often lead to a better understanding of the problem bounds, and a viable workaround until the code is fixed.
Another possible step is re-wrapping externally the AVCHD files to .mov before importing them. This should be be necessary but it might help isolate the problem. E.g, if the re-wrap utility errors out on certain files, they might be corrupted. I usually use ClipWrap: http://www.divergentmedia.com/clipwrap
ReWrapAVCHD is free and supposedly does the same thing but I have not tested it: http://www.macupdate.com/app/mac/39800/rewrapavchd
Joe Marler
on Mar 13, 2016 at 9:32:11 pm
In my above post, I meant re-wrapping AVHCD externally should *not* be necessary, but doing so might help understand the problem provide a workaround.
Robert Rinkewich
on Mar 14, 2016 at 9:00:53 pm
Joe,
Its very basic edits. We cover sports events and are supplying an mp4 (.mv4) to each participant. There performances range from 1 to 3 minutes.
I'm just marking an in and out point for each person in the clip window (I think thats what its called), and then dragging the clip to the timeline, hitting Command T for a fade up and down, and then sharing that clip with a unique name. Very simple stuff.
It happens very random, so far 3x's in the last hour. Once I had 4 clips lined up in the "background tasks" share window. Another time two shares, and just recently only had 1 clip sharing and it crashed.
Like I said this is very basic stuff, not titles, edits, effects, etc, just a fade up at the beginning and at the end. Theres nothing to render in the project by the time it shares.
Its the same stuff I've done in the past, last time was in September. Not sure how many upgrades that was ago. And its on two computers, the one I had back in Sept and one I just purchased this past week.
I just think its a bug.
