Share to DVD takes "forever"
Patrick Donegan
on Feb 22, 2016 at 11:56:45 pm
Is it just me or do other people notice that it takes "forever" to output a timeline to a DVD-Video?
the one I did earlier took about 3 hours, then I noticed an error, so I make the correction,
and then after half an hour the background tasks still save 2% complete.
The video is a little under 2 hours.
It was shot in SD on a Panasonic HVX-200. A 26.3 GB of files with some titles
and a time / date stamp.
Still on 2% 10 minutes later.
an hour ago the FCPX had "hung up" so I had to force quit and then re-start the system.
Any clues would be appreciated!
FCP X 10.2.2 - user since FCP 1.25
iMac mid 2011, MBA mid 2012
HVX-200, Shure wireless mic
Noah Kadner
Re: Share to DVD takes "forever"
on Feb 23, 2016 at 12:53:28 am
I would export to ProRes and then take that into Compressor for MPEG2/DVD rather than do it all out of FCPX. That export time includes rendering everything in your time and downconverting it too. Plenty of time for something to go wrong and waste the whole effort.
Noah
FCPWORKS - FCPX Workflow
FCP Exchange - FCPX Workshops
Patrick Donegan
on Feb 23, 2016 at 1:05:32 am
By "export to ProRes"
do you mean "Share to Master File" that is ProRes and a 2 hour file will be 40 GB?
or "Send to Compressor" and in compressor do "Burn Disk"?
Patrick in Puna Beach
FCP X 10.2.1 - user since FCP 1.25
Miller Solo tripod
Noah Kadner
on Feb 23, 2016 at 5:44:39 am
Both actually but sounds like you need to do some basic troubleshooting on your system and install if X is dying so much.
Noah
Patrick Donegan
on Feb 23, 2016 at 1:01:22 am
And now FCPX has gone to lala land 3 times, and I have to force quit one more time.
Mark Suszko
on Feb 23, 2016 at 9:46:09 pm
DVD share problems, I opine, often come from logjams in memory space allocation/ drive choices. Since it has to build the entire disk virtually before burning it, sharing to DVD needs plenty of free space in Virtual RAM as well as system RAM.
How much space is in your boot drive and in the Av/RAID array?
Patrick Donegan
on Mar 2, 2016 at 3:50:25 am
The Mavericks Boot drive has about 50 GB free at the moment,
and the USB 3 Seagate drive that the project is on has a few hundred GB free.
and 18 GB of RAM.
iPhone 4
Miller Solo tripod
Advanta-Jib
Bret Williams
on Feb 24, 2016 at 2:02:55 pm
You seem to be quite aware of the amount of time. You're not sitting in front of the computer working in X while its exporting in the background are you? Because while it is a background task, it completely pauses whenever you're doing anything in X.
If you truly want to do it in the background you'll need to export your final master to ProRes, then drop that file into compressor and do the same process there.
Bill Davis
on Mar 4, 2016 at 12:28:15 am
Also, what are the settings on the project you"re importing the SD files into?
If there's a raster mismatch of any kind, X will potentially spend a LOT of effort mapping the raster of the old clips to the new project standard with high precision.
Use Mediainfo or something similar to be SURE of the incoming clips raster and use THAT for the receiving project.
Then X won't have to waste time calculating any changes.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
