Colour/ hue shift in video footage
Rafe Gibbons
on Feb 22, 2016 at 1:08:19 pm
I'm having an issue with the color of my footage.
Very suddenly during the clip, it shifts from green to pink and back again.
The clip below shows an example - if you look at the first picture of the girl's face it dips into green then pink...
The factors at play here are:
Filming on A7s - XAVCS mode
Filming in Slog2picture profile - using an Slog2 to 709 LUT converter within fcpx
Filming with 28-70 zoom kit lens
Editing in Final cut pro version 10.1.3
Exporting as Apple Prores - but same occurs with h.264
Thanks for any suggestions as to what the problem could be!
Production Company
Jeff Kirkland
Re: Colour/ hue shift in video footage
on Feb 28, 2016 at 6:05:59 am
What version of OS X? I vaguely remember that sort of thing happening in older versions of FCPX when OS X moved to AV Foundation but from memory it was happening when plugins were applied rather than just a straight export. Could be related though as you are running a fairly ancient version of FCPX.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia | G+: | Twitter: @jeffkirkland
Richard Jacana
on Mar 15, 2016 at 6:42:08 am
Not that this is directly related to your problem but I noticed when using a LUT in FCPx when the footage is paused vs when playing the footage has a greener cast to it. Probably some bug. Not sure why your issue does not effect the entire clip though.
© 2018 All Rights Reserved
