Quick way to ID codecs at finder level?
Larry Watts
on Jan 25, 2016 at 10:43:42 pm
I've been told that FCPX shows the original codec in the inspector even if its been transcoded to prores. I want to be certain I don't have any H.264 codec mov files in my project.
Is there a utility that lets you click on a file and see the codec while in the finder?
I went to the library and copied a file that had been transcoded to PR 422 and imported it back into my library and it did ID it as prores in the inspector. I don't want to reimport all the files just to see the codec in the inspector, however.
Tangier Clarke
Re: Quick way to ID codecs at finder level?
on Jan 25, 2016 at 11:35:09 pm
This doesn't answer specifically what you want, but if you don't get an answer consider Mediainfo.
https://mediaarea.net/en/MediaInfo
It's very useful and helpful.
Tangier
Jeff Kirkland
on Jan 26, 2016 at 12:10:43 am
There are several app's called media info, media-info, mediainfo, etc. but the one linked to above is available from the Mac App Store and is always one of the first things I install on a new Mac.
Warren Eig
on Jan 26, 2016 at 5:39:06 pm
Command I. Get info in the finder. Twirl down More Info: Codec info is right there.
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
