Prepping for DVD Creation - looking for best practices for settings
Lawrence Eaton
on Jan 19, 2016 at 5:19:06 pm
I thought I'd seen the last of my blue drinks coaster media, but low and behold,no!
So simply, can anyone suggest a best practice document or better still any particular settings they've discovered to create the magic sauce, please?
Here are my thoughts:
1) Output Master file from FCPX
2) Import to Compressor
3) Use Create DVD destination
4) Cringe and wait patiently as I burn through a stack of DVD's finding the quality to encoding to bit rate balance I need.
Can anyone help me out please? More specifically, what settings for a Master file, if any, would be ideal and then what settings in Compressor would be ideal?
Regards,
Lawrence
Noah Kadner
Re: Prepping for DVD Creation - looking for best practices for settings
on Jan 19, 2016 at 8:26:28 pm
i'd go ProRes so you have a solid enough source for the MPEG2 downconvert. It often looks better than going straight from a timeline to MPEG2- for whatever reason.
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
Lawrence Eaton
on Jan 19, 2016 at 8:52:53 pm
Noah,
I went with a Master File with ProRes 422HQ - just because. Output was, quite happy to say, exquisite. When I used the Create DVD destination in Compressor, the end result looked a tad 'feathered' or out of focus. Would this be a factor of down encoding to MPEG2?
Lawrence
Noah Kadner
on Jan 19, 2016 at 10:34:30 pm
That would depend on your settings in Compressor but considering it's highly compressed MPEG2 @ 720x480 vs the 1920x1080 ProRes or better I'm assuming you're coming from... it is what it is.
Might want to confirm you're doing something like: https://larryjordan.com/articles/compressor-dvd-compression-settings/
Noah
Patrick Donegan
on Jan 22, 2016 at 5:15:18 am
Did you input that file by hand into Compressor?
Or did you "Send to Compressor"?
I too am attempting to burn some DVD-Videos, and it aint pretty.
FCP X 10.2.2 - user since FCP 1.25
iMac mid 2011, MBA mid 2012
HVX-200, Shure wireless mic
Lawrence Eaton
on Jan 22, 2016 at 9:17:02 am
Patrick,
I shared out from FCPX with a ProRes422Hq Master File (default) - see attached image.
After that, it was using the "create DVD" destination in Compressor and clicking "Start Batch"
Lawrence
