Adjustment layer changes gamma?
Chris Stevens
on Jan 14, 2016 at 11:01:57 am
Applying an adjustment layer with a letterbox crop added & it changes the gamma of all the underlying shots?
Any ideas why please?
Chris Stevens - Waterline Media. Marine Production Company.
FCPX,Motion,AE, Resolve
Noah Kadner
Re: Adjustment layer changes gamma?
on Jan 15, 2016 at 3:46:39 am
What format is the footage? It might be getting rendered to a different color space than it was shot in originally. You're only seeing that on the letterbox because its forcing a render vs. just playing back from the original format.
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
Chris Stevens
on Jan 15, 2016 at 9:12:18 am
Thanks for the reply Noah.
The format is XAVC HD @ 100Mb/s (from a Sony FS7). I also have GoPro H264 clips in the edit which behave the same as the XAVC.
Have tried disabling the adjustment layer then applying an effect, to force a render, this does not create a shift in gamma though?
Chris Stevens
on Jan 15, 2016 at 9:14:19 am
Sorry. Correction to my last post.
The GoPro H264 clips behave in the same way as the XAVC. i.e. the adjustment layer forces a gamma shift.
Noah Kadner
on Jan 15, 2016 at 6:01:50 pm
A gamma shift where- in FCPX? Or in the finished footage playing out to a broadcast monitor?
Noah
Chris Stevens
on Jan 16, 2016 at 11:42:02 am
Gamma shift appears in FCPX UI, on monitor via Black magic Ultra I/O & on exported ProRes file.
Jeff Kirkland
on Jan 16, 2016 at 11:58:19 am
What are you using as an adjustment layer? Have you tried a different adjustment layer? What effects are applied to it? What happens if you apply the adjustment layer over footage in a new project?
Just wondering if it's the adjustment layer, or something applied to it that's causing the colour shift.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Chris Stevens
on Jan 16, 2016 at 12:28:00 pm
Using the adjustment layer from the text browser. Didn't know there was an alternative? Please advise.
Applying a letterbox crop.
Same gamma shift when in new project.
Chris Stevens
on Jan 19, 2016 at 8:43:34 am
Have solved the issue.
Opened the adjustment layer, from the text browser, into motion. Changed nothing then published it to FCPX.
All ok now. No idea why?
Noah Kadner
on Jan 19, 2016 at 10:42:26 pm
Might have had something hidden someplace that caused that shift- hard to say. In general I find copy/paste attributes a lot more predictable/useful than adjustment layers which are really more of a workaround in FCPX and not so much a built-in workflow.
Noah
