Why does changing computers cause rerendering?
Tangier Clarke
on Jan 1, 2016 at 4:33:27 pm
Does anyone understand why FCP X renders again when I change computers. My understanding is that my managed library contains the media, the render files, etc. When I move from computer to computer (work, laptop, home computer) using an an FCP X library on an external and all versions of OS X and FCP X are all the same, the project I am working on and already rendered starts going through a rerender process.
Tangier
John Rofrano
Re: Why does changing computers cause rerendering?
on Jan 1, 2016 at 6:05:07 pm
[Tangier Clarke] "My understanding is that my managed library contains the media, the render files, etc. "
Only if you set it up that way. Go to your Library Properties and make sure that the Cache is set to In Library.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Tangier Clarke
on Jan 1, 2016 at 6:39:04 pm
Yep. Had that. Have it all set to stay with the library.
Tangier
Matt Whittemore
on Oct 17, 2016 at 8:43:20 pm
Did you ever figure this out?
Tangier Clarke
on Oct 17, 2016 at 9:43:25 pm
Haven't figured it out nor gotten a response on this that answers the question.
Brett Sherman
on Oct 18, 2016 at 1:09:09 am
I have had a similar problem with cache files stored on a server. The crazy thing is, it doesn't always happen. Sometimes you open a project and everything is rendered. Other times you open it and it has to re-render everything. Other times it has to re-render some things.
The best I could figure out is that it had something to do with permissions. It was far worse on projects I restored from a backup.
Brett Sherman
One Man Band (If it's video related I'll do it!)
I work for an institution that probably does not want to be associated with my babblings here.
