Display Clock is cut-off
Charles Carmichael
on Dec 15, 2015 at 12:27:46 am
Anyone experiencing the same issue? My display clock on the lower left is cut-off when I'm playing a video. How can I fix this?
John Rofrano
Re: Display Clock is cut-off
on Dec 15, 2015 at 1:39:45 am
Drag the right edge to resize it and the text should snap back to the correct size.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Andrzej Wozniak
on Dec 15, 2015 at 11:15:11 am
Yes, I have the same problem. There is some distortion lines showing on the TC display. It seems that it is some sort of an error in FCPX under El Capitan. Hopefully Apple will fix this with with the next update.
John Rofrano
on Dec 15, 2015 at 1:59:49 pm
[Andrzej Wozniak] "It seems that it is some sort of an error in FCPX under El Capitan. Hopefully Apple will fix this with with the next update."
I had the same problem and I'm using Yosemite and all I had to do was resize the window and the text snapped back to fill it. Does this not work for you in El Capitan? I'm about to upgrade to El Capitan.
~jr
Andrzej Wozniak
on Dec 15, 2015 at 2:15:27 pm
Hi John,
resizing the window does not work for me at all. Here is more info on this problem.
http://www.fcp.co/final-cut-pro/articles/1725-timecode-window-bug-with-fina...
I have actually reported this bug to Apple today.
Bret Williams
on Dec 15, 2015 at 2:42:31 pm
You're talking about two different things. In El Capitan you're going to have issues with the TC display (not the breakout window). Look closely at the screen shot and you'll see a nasty line of junk through the numbers and also the hr min sec fr type across the bottom is offset. They don't line up with their numerical counterparts above. It doesn't affect anything but the visual.
John Rofrano
on Dec 15, 2015 at 8:05:18 pm
Sounds like I should hold off on upgrading to El Capitan until Apple works out some more bugs. El Capitan was the first time I received 3 emails from Arturia, Native Instruments, and iZotope all warning me not to upgrade because it will break their plug-ins. Whatever Apple did... they either didn't test very well or didn't care about backward compatibility but I'm thinking of holding of on upgrading to El Capitan for a while.
~jr
Andrzej Wozniak
on Dec 15, 2015 at 8:09:52 pm
If you do not need the upgrade then I would suggest to wait untill you really have to.
Best regards,
Andrzej Wozniak
Bret Williams
on Dec 15, 2015 at 8:10:51 pm
There is absolutely zero benefit to El Capitan that I can tell. I was hoping for this whole Metal thing, but I guess nobody is even doing anything with it. You'd think Resolve would be all over it as their playback performance needs something.
I installed El Cap on an external partition and played with it. You still can't use dual monitors full screen for crap. Metal hasn't done anything special for anything and there's heaps of new bugs. Yay?
Bill Davis
on Dec 15, 2015 at 8:43:32 pm
I'm holding off on my ElCap switch for a little bit too.
I'm more than willing to pull the trigger on intra-release updates as they happen - but the big "named" OS updates typically require some time to settle down.
I don't mind tempting Fate a bit.
I just don't find there's any up-side in chaining her inside my machine.
YMMV.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
