Yield Sign!
Patrick Donegan
Yield Sign!
on Dec 12, 2015 at 3:22:49 am
I have the Yield sing over an icon in the Libraries viewer.
I just reconnected the slides (image files)
the yield is still there.
Also, there is one over a different Library name.
Is there a place to see where all these error messages are hiding so I have a clue
on what to fix?
Jeremy Garchow
Re: Yield Sign!
on Dec 12, 2015 at 5:48:10 pm
If everything is actually relinked, then a restart of the app usually gets rid of the caution sign.
Patrick Donegan
Re: Yield Sign!
on Dec 14, 2015 at 1:51:19 am
argh - the Yield sings are still there!
How do I find out what they are referring to?
FCP X 10.2.2 - user since FCP 1.25
iMac mid 2011, MBA mid 2012
HVX-200, Shure wireless mic
Jeremy Garchow
Re: Yield Sign!
on Dec 14, 2015 at 1:55:01 am
Something is still offline. You could look in the browser and see if you see a red offline sign, or select the library and choose File > Relink Files and select the radio button to "missing" and see if X reports which files are still missing.
Patrick Donegan
Re: Yield Sign!
on Dec 14, 2015 at 2:05:24 am
Thanks - I will check that way again.
I made the mistake of "organizing " some slides, but in the finder in the Project library ..
and then now there are many errors, even after I put the files back into the top level of
And I read that sometime it means a project has not finished rendering ....
I really wish I could right click and show the error reason..
and while we are at it, it is none of these:
https://support.apple.com/kb/PH12711?locale=en_US&viewlocale=en_US
Jeremy Garchow
Re: Yield Sign!
on Dec 14, 2015 at 2:11:27 am
What does it look like? A yellow sign with an exclamation point?
Patrick Donegan
Re: Yield Sign!
on Dec 14, 2015 at 4:15:19 am
Let me see if I can attach a screen shot:
9561_screenshot20151213at6.05.25pm.png.zip
/Users/patrick/Desktop/FCPX yield .png
Jeremy Garchow
Re: Yield Sign!
on Dec 14, 2015 at 4:28:43 am
Yes. That's media offline.
In the Browser, do you see any red clips that are offline?
Patrick Donegan
Re: Yield Sign!
on Dec 14, 2015 at 9:38:24 pm
Nope - I don't see any media that is off line in those clips.
It could also be that the rendering is not complete.
I really wish I could just right click and see where the error are.
Jeremy Garchow
Re: Yield Sign!
on Dec 14, 2015 at 9:56:00 pm
[Patrick Donegan] "Nope - I don't see any media that is off line in those clips."
If you select the event and chose File > Relink Clips and click the "Missing" Radio button, are there any clips listed?
Doug Metz
Re: Yield Sign!
on Dec 15, 2015 at 2:09:23 pm
I have seen the the Offline indicator on my setup with all media connected - it turned out to be a missing transition. I'd been cleaning up my effects / transitions / generators (removing demos, etc.), and I had inadvertently left a demo transition in one of my projects.
Something else to check...
Doug Metz
Anode
Craig Alan
Re: Yield Sign!
on Dec 16, 2015 at 12:48:37 pm
Maybe try to consolidate the media in your location of choice - even though it's there already. This time letting FC complete the task rather than doing it in the finder. Another possibility is to delete preferences.
Reset preferences in Final Cut Pro X 10.1.2 or later
Quit Final Cut Pro X.
Hold down the Command and Option keys while reopening Final Cut Pro X. A window will appear asking "Do you want to delete preferences?"
or sometimes just rebooting computer does the trick.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
