Caution: Inspector parameters unresponsive in realtime since OS X 10.11.2 update.
Tangier Clarke
on Dec 11, 2015 at 5:03:03 pm
I recently did the software update to OS X 10.11.2
I know longer have realtime responsiveness from FCP X when making adjustments with parameters for effects, transforms or any parameters. I used to be able to see things happening while I make adjustments. Now I only see them after; and sometimes not at all.
I am going to dump my FCP X prefs and see if that solves anything, but thought I'd let folks know.
Tangier
Tangier Clarke
Re: Caution: Inspector parameters unresponsive in realtime since OS X 10.11.2 update.
on Dec 11, 2015 at 5:05:15 pm
For the record it seems to be bound to one library and not others.
Tangier
Bret Williams
on Dec 11, 2015 at 6:48:31 pm
Still have the TC window bug?
Tangier Clarke
on Dec 11, 2015 at 6:52:15 pm
Funny, I hadn't noticed that it is in fact better. However not totally. It's not clean like before the bug happened, but there aren't as many strange lines anymore. Now there's just a small spot over the last frame number space and a couple of spots that look like dead pixels - and they aren't dead pixels.
So it's sort of fixed.
Tangier
Bret Williams
on Dec 11, 2015 at 6:54:57 pm
It actually changes every time you launch the app. But what about the words under the counter? Are they still misaligned?
Tangier Clarke
on Dec 11, 2015 at 6:59:13 pm
Still misaligned.
Tangier
