Render a crossfade on a new iMac 27 inch 5K Retina
Adam Berch
on Nov 27, 2015 at 2:48:03 pm
I'm running FCP X 10.2.1. I have an iMac (Retina 5K, 27 Inch with 3.2 GHZ Intel Core i5 with 16GB RAM and an AMD Radeon R9 M380 2048 MB Graphics Card.
How come when I put a simple crossfade between 2 clips I still have to render that crossfade?
I tested it on Proxy and Original.
Is there a way or setting where I don't have to render a crossfade?
Thanks in advance
Noah Kadner
Re: Render a crossfade on a new iMac 27 inch 5K Retina
on Nov 27, 2015 at 5:33:10 pm
Depends entirely on the source footage, MVI suggests this is H.264 from a camera? Yep it's got to be rendered...
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
John Rofrano
on Nov 28, 2015 at 3:21:09 pm
It has to be rendered because you are creating a new composite from existing frames by gradually blending one into the other. If you have background rendering turned on it should get rendered in seconds and you won't even notice it's happening. There is nothing for you to do here, Just let background redding perform it's magic.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Noah Kadner
on Nov 29, 2015 at 8:29:33 pm
Also a fast enough GPU on your system will real time preview those so quickly background or foreground rendering wouldn't even be necessary.
Noah
