Detach 2 Audio sources from multi clip
Adam Berch
on Nov 6, 2015 at 6:00:30 pm
HI,
As you can see from the picture below, I am working with a multi clip. This multi clip has 3 seperate audio tracks. (2 are attached to video clips and 1 is an H4N clip)
How can I detach the 2 audio sources so they are 2 seperate files instead of the one you see in the picture. (1 from a video clip and the other the H4N)? I have one of them detached, but I want to detach the other one as well?
Thanks in advance
FCP X 10.2
Mac Pro
Noah Kadner
Re: Detach 2 Audio sources from multi clip
on Nov 6, 2015 at 7:33:07 pm
jump into the multicam clip and copy the tracks you want- then paste them back into the project timeline.
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
Bret Williams
on Nov 6, 2015 at 10:19:31 pm
Can also open up the audio from first clip and drag out the audio under all the others as an L cut.
Noah Kadner
on Nov 7, 2015 at 12:01:06 am
Or copy paste and select a different audio angle. Generally speaking I recommend against detaching audio if you can at all help it as there is no reattach audio nor sync offset indicators as FCP 7 had.
Noah
