Editing RGB 4:4:4 footage from Canon C300 MKii
Dan Hundley
on Oct 29, 2015 at 10:12:05 pm
Trying to import Canon C300 MKii RGB 4:4:4 12-bit 2k footage into FCPX 10.2.2 with no luck. DaVinci Resolve 12 lite will not accept it either. Premiere Pro CC 2015 is the only app that will import it.
Has anyone experienced anything different?
Would like to use this format for green screen work and edit in FCPX. Any workflow suggestions would be appreciated. I could convert all the files to ProRes444 in Premiere, just not ideal.
Boris Jansch
Re: Editing RGB 4:4:4 footage from Canon C300 MKii
on Nov 10, 2015 at 10:13:31 am
I'm trying to do exactly the same without luck unfortunately. PP CC is just so boring to use after FCPX so I'm just hoping Apple sort it in the next few days with an update.
Bit of a major bummer really and the camera has been out for a couple of months now so what gives Apple!?!
Many thanks,
Boris J.
Jerry Hofmann
on Nov 13, 2015 at 6:14:16 pm
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/c...
Has a driver for FCP X... might work?
Jerry
Dan Hundley
on Nov 13, 2015 at 6:29:49 pm
Thanks for the reply but that looks to be a C300 driver, not for C300 MKII.
As a temp solution, I've been able to use Adobe Media Encoder to batch transfer the files to ProRes 4444.
Jason Sedmak
on Nov 16, 2015 at 11:28:31 pm
Has anyone come up with the correct workflow for this yet?
I've been able to apply some of the Clog2 LUTs in Resolve but the files have to be converted just so Resolve can see them.
Dan Hundley
on Nov 17, 2015 at 5:01:22 pm
For the 12 bit footage, I've been transcoding in Adobe Media Encoder to ProRes444 and then adding the Clog2 LUTs in FCPX with LUT Utility.
Bob Woodhead
on Nov 30, 2015 at 11:39:30 am
Dan, I tried this, and Media Encoder seems to hang when I start the transcode. It can scrub the 12 bit 444 clip OK, so I know it can "see" it, but it just doesn't move forward on the transcode. Could you export/zip up the preset you're using & send it to me? Perhaps there's something wonky with the custom preset I created. I'm editingfx@gmail.com Just shot a bunch of test footage, and didn't realize I'd be stuck on the FCPX connection. Thanks!
"Constituo, ergo sum"
Bob Woodhead / Atlanta
CMX-Quantel-Avid-Premiere-FCPX-AFX-Crayola
"What a long strange trip it's been...."
Dan Hundley
on Nov 30, 2015 at 6:07:20 pm
I'm using Media Encoder CC 2015. Just selected format "Quicktime" and codec "Apple ProRes 4444". Nothing else.
Bob Woodhead
on Nov 30, 2015 at 6:23:20 pm
Well, spit. Not sure what happened before... ME appeared to be "stuck" on the first frame, but no error, and the time remaining was running. Just did it with your setup, and it worked. Still seemed to hang for a few seconds (ie, the blue progress bar wasn't moving) but then it took off. I was messing with a few more encode settings, beyond the default after selecting ProRes 4444, so maybe it was op error.
Right, now just need Canon/Apple/someone to give us a native import for 444.
OT - anyone know which external recorder works with Canon RAW? That is, it records RAW. We have a Atomos Shogun, which sees the RAW, but records as ProRes 422.
Mark Dobson
on Feb 2, 2016 at 3:29:20 pm
[Bob Woodhead] "Right, now just need Canon/Apple/someone to give us a native import for 444.
OT - anyone know which external recorder works with Canon RAW? That is, it records RAW. We have a Atomos Shogun, which sees the RAW, but records as ProRes 422."
Hi Bob - a bit late to this conversation, but as I'm preparing to use C300 Mk2, are you saying you can record 4k externally as a ProRes 422 file? If that is the case do you know the bit rate?
thanks
Dan Hundley
on Feb 16, 2016 at 7:34:00 pm
Hurray! FCPX 10.2.3 now allows importing of Canon's C300 MKii RGB 4:4:4 footage
Kate Heller Thomas
on Apr 14, 2016 at 9:02:59 pm
It's not working for me, is there a driver or plug-in I need?
Dan Hundley
on Apr 28, 2016 at 7:47:51 pm
Have you installed this plugin?
Canon XF Plugin for Final Cut Pro X 3.1
Kate Heller Thomas
on May 2, 2016 at 2:37:26 pm
Yes. I d. I finally got it to work after updating the os on my computer. Apparently I had missed a pro video formats update.
