FCPX Voice over issues
Robert Parrish
on Oct 24, 2015 at 7:21:50 pm
After installing El Capitan, voice over starting recording with the pitch slightly up, random echo, and random instances of static. I'm running 10.2.2.
Using H4n as a usb pass through for a Rode NT1-A.
The time readout has also gone batty. As you can see the attached image.
Thanks for any help!
Doug Metz
Re: FCPX Voice over issues
on Oct 26, 2015 at 2:55:33 pm
Do the settings on the Zoom (bit rate / sample rate) match those of FCPX? Maybe also have a peek in Audio MIDI Setup...
The timecode display issue is a known bug with El Capitan. It shows correct TC, just the labels are wonky.
Doug Metz
Anode
Robert Parrish
on Oct 30, 2015 at 11:34:33 am
Thank you Doug. I'll look into that.
Robert Parrish
on Nov 1, 2015 at 9:40:38 pm
Problem solved. The zoom was 44 kHz and the project was at 48 kHz. Thanks!
Wayne Robbins
on Nov 14, 2015 at 10:06:05 pm
I am having the same problem - were you able to change the MIDI setting for the Zoom (I'm not having luck doing that) or did you adjust setting inside FCPX? Thanks for any advice!
