Gh4 workflow
Zimema Mhone
Gh4 workflow
on Oct 22, 2015 at 8:47:56 pm
I have just collected a bunch of footage documenting the Finnish summer and I would like to get some advice as to how to start 'processing' the footage.
The goal is to create a travel montage, which includes a lot of speed ramping, positioning and stabilization. The focus of the piece will be the interaction between the images, effects and sound. They are all equal in importance.
I intend on pursuing a workflow as such: select and stabilize clips/ sequences/ events in After Effects, then pre-comp and apply Twixtor as needed, pan & scan/ resize/ crop to 1080p or not, export as prores 444, import to FCPx, put it all together as a fluent series of events and rework effects as needed.
Can somoene let me know if I am heading for woes or if I am on the right track. What else should I consider?
Noah Kadner
Re: Gh4 workflow
on Oct 22, 2015 at 10:11:06 pm
Why bring AFX into the mix? FCPX can do those tasks and save you generation loss and time.
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
Bret Williams
Re: Gh4 workflow
on Oct 23, 2015 at 12:22:56 am
I was thinking the same thing. More flexible and in real time for the most part.
Zimema Mhone
Re: Gh4 workflow
on Oct 23, 2015 at 2:26:00 pm
Thanks Noah.
I intend of using curves quite a bit for movement. But I think your are right, the generation loss is not really worth the little bit of extra 'flair' I could apply in AFX. Keep it simple and the audience will thank you for it, I guess...
Eric Santiago
Re: Gh4 workflow
on Oct 23, 2015 at 3:56:59 pm
Choose key clips for AE later or prior.
I do it all the time with my GH4 and RED Scarlet.
Now thats usually post stuff.
I have never liked any of the Optical Flow options in any NLE.
Love AE Timewap ;)
Bret Williams
Re: Gh4 workflow
on Oct 23, 2015 at 6:16:22 pm
[Eric Santiago] "I have never liked any of the Optical Flow options in any NLE."
Why not? The one in X is the same as Motion and Premiere is the same as AE. They seem pretty flawless for the most part.
Eric Santiago
Re: Gh4 workflow
on Oct 27, 2015 at 12:56:30 pm
My beef is specific.
Using GoPro footage shot at 29.97 leaves anomalies everywhere specially snow footy.
Works great with my Scarlet at HFR but thats just cheating.
