How do you change in or out point of keyworded range?
Fred Hickler
on Oct 20, 2015 at 9:55:32 pm
So lets say I have a long interview clip in the browser and I select a section of it (a "range" believe is the correct term) and assign a keyword to it. Later I decide I want to change the in or out point of this range, while maintaining the keyword assigned to it. I can't find a way to do this. Is it even possible?
Noah Kadner
Re: How do you change in or out point of keyworded range?
on Oct 20, 2015 at 10:22:42 pm
You would need to go back to the original and re-keyword over the range.
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
Fred Hickler
on Oct 20, 2015 at 10:38:29 pm
So how would that work? Select the keyword, change in and out, add the keyword to the new range, select the first occurrance of the keyword (which would select the first range) and remove the keyword from that range?
Noah Kadner
on Oct 21, 2015 at 4:53:16 am
Pretty much that.
Noah
Fred Hickler
on Oct 21, 2015 at 4:42:21 pm
Bummer. Just left feedback.
