Ideal Blu Ray settings for large projection in FCPX
Paul Hanssen
on Oct 19, 2015 at 2:46:31 pm
I have to make a blu ray disk for a projection in an art house cinema. Does anyone know which settings are ideal?? I can use the standard settings but perhaps I can set them manually in FCPX for higher quality.
Best Regards
Paul
Noah Kadner
Re: Ideal Blu Ray settings for large projection in FCPX
on Oct 19, 2015 at 5:40:31 pm
Not a whole lot of leeway if you want it to play in a Blu-ray player. Better if they let you hook up a laptop and stream ProRes over HDMi.
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
Doug Metz
on Oct 19, 2015 at 7:48:30 pm
If you have Compressor 4.x (well worth the $50), it has a built-in BluRay setting - which you could set up as a Share destination in FCPX preferences...
Doug Metz
Anode
Bret Williams
on Oct 20, 2015 at 12:54:33 am
Same blu-ray settings are already in X, aren't they?
Doug Metz
on Oct 20, 2015 at 1:58:07 pm
[Bret Williams] "Same blu-ray settings are already in X, aren't they?"
Well, how about that? Hadn't seen that in the Destinations pane before... looks like there are a few more configuration options via Compressor if you're so inclined.
Doug Metz
Anode
Bret Williams
on Oct 20, 2015 at 2:00:33 pm
Same interface / options that was is FCP 7 / Compressor 3 too. Almost exactly.
