FCPX to Ableton Live 9
Daniel Elder
on Oct 14, 2015 at 4:40:13 pm
I am considering using a mixer / composer who uses Ableton Live 9 to mix his music and audio. He says he wants it in .WAV format. I have no idea what to do to send him the master timeline and the audio in a .WAV? Anyone have any suggestions on how I can get my XML to him for mastering the audio?
Thanks in advance.
Dan
Daniel Elder
producer
http://www.elderpictures.com
Noah Kadner
Re: FCPX to Ableton Live 9
on Oct 14, 2015 at 7:12:20 pm
If he can import a ProTools Session- you could make one with x2Pro. Or you could try more manually via:
https://larryjordan.com/articles/fcp-x-export-multi-channel-audio/
Noah
FCPWORKS - FCPX Workflow
FCP eXchange - FCPX Workshops
Daniel Elder
on Oct 14, 2015 at 11:14:13 pm
Thanks so would I only be able to get it to ableton via pro tools? I'm trying to convince him to get Logic Pro or pro tools so it can be a little easier of a round trip.
Daniel Elder
producer
Noah Kadner
on Oct 15, 2015 at 1:37:54 am
Not sure- but I know of no tools that would make an Ableton session as quickly as you can get a ProTools session going.
Noah
Doug Metz
on Oct 19, 2015 at 9:34:50 pm
[Daniel Elder] "I am considering using a mixer / composer who uses Ableton Live 9 to mix his music and audio. He says he wants it in .WAV format. I have no idea what to do to send him the master timeline and the audio in a .WAV? Anyone have any suggestions on how I can get my XML to him for mastering the audio?"
If he's looking for WAV files to do the mix, you could export this directly from FCPX.
First thing is to make sure you've got Roles properly assigned for all clips in your timeline. Then share / export 'Master File' as shown below. You can then do a low-res mp4 of the video that he can use for sync.
Doug Metz
Anode
