Move clips freely; not frame by frame
Jeroen van Weperen
on Oct 10, 2015 at 7:45:31 pm
Hello,
I'm editing a video in which I need to move audio quite precisely, but the video needs to move with it (So it's still synced with the audio). Now when I move the clips, I can only move it frame by frame. Is there a way I can override this, and move the clips freely?
Thanks in advance,
-Jeroen
Bret Williams
Re: Move clips freely; not frame by frame
on Oct 10, 2015 at 8:28:57 pm
You can detach the audio from the video and move it very precisely. But you're obviously limited to moving video within the physical constraints of the frame rate of your timeline.
Jeremy Garchow
on Oct 11, 2015 at 2:50:45 pm
You can move audio by subframe, but video can only move frame by frame.
