Working with 24 and 30 FPS in same project
Adam Berch
on Oct 1, 2015 at 1:27:46 am
HI,
I have footage that was shot on 2 DSLR cameras. 1 was shot at 24 fps and the other was shot at 30 fps. and 2 H4N Audio Files.
It's all one job that I put on the same timeline after I edited it. Will these different Frame Rates affect the job in any way? I can edit using different frame rates, correct?
Is there a way to make all of the 30 FPS footage be imported at 24 FPS to keep things the same? Or Vice Versa? Would I have to do anything to the audio on import as well if I do this?
FCP 10.2
Jeff Kirkland
Re: Working with 24 and 30 FPS in same project
on Oct 1, 2015 at 2:39:31 am
I'm just finishing up an edit that was 25p and 30p freely intermingled so I can't imagine that you'll have an issue. FCPX tends to handle that sort of stuff very well.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
