Exporting XML _ audio track problems
Steven Gladstone
on Sep 30, 2015 at 4:39:40 am
Hi, I have an edit I want to bring into resolve 12, Export XML no problem, it opens in resolve twelve. The problem is in the edit I have scratch tracks and a clean audio track. I synchronized the clips, and disabled the scratch tracks - plays back fine in FCPX, but in Resolve 12, all the individual audio clips are now the same, with the clean track and the scratch track merged and playing back as three identical audio tracks.
How can I export the audio without the scratch tracks? I can't delete the scratch tracks, and exporting as XML only combines the audio tracks. HELP please, it is driving me mad.
Steven Gladstone
http://www.gladstonefilms.com
Jeremy Garchow
Re: Exporting XML _ audio track problems
on Sep 30, 2015 at 1:21:35 pm
I find the easiest way to do this is to make a duplicate Project, break apart the audio and delete the channels you don't need.
I haven't played with 12 a whole lot yet, so there may be a way to do this in 12 as well.
Jeremy
Bret Williams
on Sep 30, 2015 at 2:32:13 pm
I had the exact issue with synced clips coming across incorrectly in 12. There were a number of issues. First, the disabled tracks were enabled in 12. But I also had to "open in timeline" the clip where I discovered more audio tracks that needed to be disabled. So it seems that a synced clip is being considered a compound, and at the same time attaching the synced audio outside the compound. Basically it's a mess. So I deleted the "scratch" clips in resolve by option selecting them. Then I decomposed the clips in place which exposed all the compounded audio and then deleted those. Finally I was left with the video and the synced audio which I relinked back to their video one by one with cmd option L.
Steven Gladstone
on Sep 30, 2015 at 4:04:40 pm
Thats great, thanks.
How do you decompose the clips?
Steven Gladstone
Steven Gladstone
on Sep 30, 2015 at 4:06:12 pm
Found it, you rule.
Steven Gladstone
Bret Williams
on Sep 30, 2015 at 4:31:57 pm
Don't know about that. Just a day ahead with same problems!
Have you found the ofx effects panel yet? I installed universe premium just to have a set of basic transitions, generators and effects. But the effects aren't in the same place. They're in the color panel.
Steven Gladstone
on Sep 30, 2015 at 4:50:08 pm
I've just started on Resolve 12 - abandoning FCPX
Steven Gladstone
