custom titles
Roy McKenzie
custom titles
on Sep 21, 2015 at 8:44:08 pm
Has anyone else experienced this? I added a new custom title to the timeline and animated it on with the published parameters, but when I change the look to an outline (outline the text and turn off "face") it only shows the outline after the animation!
So during the animation on/off FCPX produces white text, then when the animation is done it shows the outline (proper the way I designed it).
Running 10.2.2
Thank you
Roy
Noah Kadner
Re: custom titles
on Sep 21, 2015 at 9:30:56 pm
I'd send in a bug report if you can make it happen reliably and repeatedly.
http://www.apple.com/feedback/finalcutpro.html
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Roy McKenzie
Re: custom titles
on Sep 22, 2015 at 1:35:17 pm
I probably won't. I can't believe I didn't try this sooner but the work around is to take the opacity to zero on the face and leave it active. Shutting the face off causes the problem.
Thank you
Roy
Doug Metz
Re: custom titles
on Sep 22, 2015 at 3:30:56 pm
[Roy McKenzie] "I probably won't. I can't believe I didn't try this sooner but the work around is to take the opacity to zero on the face and leave it active. Shutting the face off causes the problem."
Still sounds like a bug... glad you got it sorted, though!
Doug Metz
Anode
