Modify Audio to be at -12 db.
Adam Berch
on Sep 15, 2015 at 12:19:43 am
If I am adjusting my audio tracks to peak at -12 or 16db, is there a way to Modify Audio and pick the db you want it to be be peaked at (I did this in FCP 7 all the time) or do I just have to keep adjusting the volume until I get it to where I want it?
Bret Williams
Re: Modify Audio to be at -12 db.
on Sep 15, 2015 at 12:30:20 am
How did you do this in FCP 7?
Craig Alan
on Sep 15, 2015 at 4:51:10 am
normalize. and broadcast safe. used to act as limiters. not sure why -12? why not -6? haven't used 7 in a couple of years so I might be wrong.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
John Rofrano
on Sep 16, 2015 at 2:29:47 am
The answer can be found in the Audio Hard Limiter thread. Basically you set up the Compressor as a hard limiter and save the preset and then apply it to all of your audio clips with cut-n-paste, or else as a final step, make a compound clip of all of your audio clips and apply it to the compound clip before rendering.
~jr
http://www.johnrofrano.com
http://www.vasst.com
