Removing bouncing stuck pixel
Daniel Horn
on Sep 9, 2015 at 12:16:02 am
New to FCPX, worked in 7 for a few years but I'd like to fix this in X if I can grasp it. I made a video and I'm very happy with it but I have a bright green pixel that's stuck and I can't figure out how to get it out. What's making it more difficult is that I used stabilization and zoomed a bit on some of the shots so it's effectively making the pixel bounce around and move positions. I was hoping to just isolate the color with a keyer, remove it and apply that to every clip but I just can't figure it out. What could I do?
Noah Kadner
Re: Removing bouncing stuck pixel
on Sep 9, 2015 at 6:09:37 am
Can you post an example screenshot. That's generally a fixable flaw though not a stock built in function (of any editor I'm aware of...).
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Mark Suszko
on Sep 9, 2015 at 3:01:54 pm
May I suggest Digital Heaven which offers a dead pixel remover.
I think to do this right, you really need to go back and treat the original footage, then re-import it into the finished project and re-do all the other things you did to it.
Nick Meyers
on Sep 10, 2015 at 1:59:17 pm
you want to post this in the FC X techniques forum
this is for FCP & and under.
however, the simplest approach would be to fix the dead pixel BEFORE you do the stabilising.
nick
