Sound clips all the time.
Lucy Slavinsky
on Aug 30, 2015 at 4:40:42 pm
Hello all,
Never ever have had this problem before - for some reason the sound in the time line clips all the time. The original footage is Ok. I tried to import the sound separately and replace the one in the time line. No use. As soon as it gets in the time line it starts clipping. And it sounds pretty bad. Please help!
Thank you very much in advance.
Oliver Peters
Re: Sound clips all the time.
on Aug 30, 2015 at 5:17:49 pm
[Lucy Slavinsky] "As soon as it gets in the time line it starts clipping. And it sounds pretty bad."
What are the specs of the source audio? For example, if it's 32-bit audio, which is common in the Adobe world, FCP X might have issues. Ideally, it should be 48K, 16-bit or 24-bit, WAV or AIF.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Lucy Slavinsky
on Aug 31, 2015 at 12:03:51 am
Thank you for your response. The project setting is 48kHz, ProRes. When I imported the fila a second time I just used the audio track to override the original one. The same problem - as soon as it placed in the time line it starts clipping. Do you need any other info? Thank you once again
Oliver Peters
on Aug 31, 2015 at 12:59:24 am
Seems odd. What are the timeline settings? I presume stereo. Does it looks like your source tracks are being summed into a combined mono output? Try trashing your FCP prefs or try a new library and see if that makes any difference.
- Oliver
Orlando, FL
Noah Kadner
on Aug 31, 2015 at 1:31:03 am
How are you listening? Is it routed through something or just the Mac's built-in speakers.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Lucy Slavinsky
on Aug 31, 2015 at 1:33:24 am
Mac speakers.
Lucy Slavinsky
on Aug 31, 2015 at 1:32:29 am
Yes it is stereo. I am not sure about summed tracks. How can I check if it summed? I trashed the preferenses. There iis still clipping in the old library, but no more clipping in the new library. Does it mean I have to redo 2 days of my work or there is a way to fix this problem in the old library. Thank you very much!
Jeff Kirkland
on Aug 31, 2015 at 10:55:32 am
Try creating a new library and copying the project into it. With any luck the audio issue will be left behind.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Lucy Slavinsky
on Aug 31, 2015 at 9:32:26 pm
I created a new library and copied and pasted the project. Unfortunatly, no luck. It is clipping. What else should I try?
Thank you!
Bret Williams
on Aug 31, 2015 at 10:10:41 pm
Obvious perhaps, but have you tried lowering the volume of the clip? How many channels does the clip have? Is it visually clipping in the waveform? Is it clipping in the meters?
