Dropzone publishing
Arne Hemmer
Dropzone publishing
on Aug 23, 2015 at 3:25:18 pm
Hello...
I work with motion 5.2.1. & FCPX 10.1.4
I published a couple of generators and transitions via motion and everything worked fine. I could fill the dropzones in FCPX.
But now it's not working anymore. When i publish a new transition or generator FCPX will not show the dropzone. When I put the generator in the timeline it allways shows the "red picture with the yellow warning sign"...
Same happens when i re-publish older generators.
But older generators that are already in FCPX work fine...
I wanted to finish a couple of projects before updating to FCPX 10.2
...if that even is of any help
Thanks for any help...
Noah Kadner
Re: Dropzone publishing
on Aug 23, 2015 at 5:25:20 pm
I'd go ahead and update- not sure you're gaining anything by staying at the older version and it could well be the cause of this issue.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
