Multicam issue, any thoughts are appreciated...
Christian Friis
on Aug 7, 2015 at 10:23:41 am
I'm trying to sync 2 cameras in FCPX, talking head footage, 2 angles. I use the auto function syncing by audio, but the result is that the 2 clips are placed one after the other. Any ideas why this happens? Thanks in advance!
Christian.
Christian Friis
Re: Multicam issue, any thoughts are appreciated...
on Aug 7, 2015 at 11:03:45 am
Solved! The issue was that the 2 cameras had the same name (as they were same brand and model). So I changed the camera name + the angle name. Dont know which of the 2 info points did it.
http://www.oddresort.com
Robin S. Kurz
on Aug 7, 2015 at 11:26:27 am
[Christian Friis] "Dont know which of the 2 info points did it."
It will have been the angle name. Setting a different angle ORDER in the setup would have done it also.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
