Mono Audio Channel outputs on CH 3
Tobias Heilmann-Schuricht
on Aug 5, 2015 at 8:16:03 am
I have a source clip, with one audio channel set to mono. When looking at the inspector I also see the audio setting for that clip as MONO.
I see the audio on the FCPX meter (which also only shows mono). But I can not hear the audio as somehow this audio channel is being routed to CH3 on the output. I see this from my external audio meter de-embedding the SDI audio.
When I switch the audio setting of the clip from MONO to LEFT, for example, the audio maps to CH1 and I can hear it.
Why would the MONO setting map to CH3?
I am running the latest versions of every software on the system.
Thanks for any thoughts.
Tobias
In Touch Media GmbH
Germany
Jeremy Garchow
Re: Mono Audio Channel outputs on CH 3
on Aug 5, 2015 at 12:43:45 pm
What kind of output hardware are you using and how do you have that configured?
on Aug 30, 2015 at 9:06:46 am
I am using BMD Ultra Studio 4K connected through TB2.
There really isn't much configuring I can detect in the control panel that would affect this issue.
I am listening to my stereo sum (Ch1+2) via AES/EBU
I am seeing the channel mapping on my SmartScope 4K which is looking at the HD-SDI signal
In Touch Media GmbH
Germany
Jeremy Garchow
on Aug 30, 2015 at 2:06:35 pm
I'd have a look at this: https://support.apple.com/en-us/HT204780
on Sep 13, 2015 at 8:48:15 am
Jeremy, thank you! That solved the problem...
In Touch Media GmbH
Germany
