Separate audio with Sony CX900 and Final Cut PRO/X
Casimir Artmann
on Aug 5, 2015 at 6:43:34 am
I have recorded a few clips with a Sony CX900, XLR-K2M adapter and two Røde lavs with XLR-connectors.
My problem is that I can't separate each channel in edit in Final Cut when recording sound with videocamera,
It works as supposed with a recording done via a Focusrite Scarlett 2i2 to computer when I separate the channels in Audacity. if importing as a stereo, then it's the same as with the camera. It also works with my Zoom H2N or a borrowed Zoom H6.
Is it a limitation with the camera or with Final Cut? Plan B is to buy me a Zoom H6 to record sound separate as I know that it works as I have a four interviews to be shot next Friday.
/Casi
Noah Kadner
Re: Separate audio with Sony CX900 and Final Cut PRO/X
on Aug 5, 2015 at 4:56:45 pm
What's the channel configuration like in the Inspector? That's how you determine whether clips are expressed as summed stereo or mono pairs, etc.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Casimir Artmann
on Aug 5, 2015 at 6:58:08 pm
These are the buttons and dials on the Sony XLR-K2M adapter.
  • If you set ch1 on Rec Channel Select will input 1 goto ch1 and input 2 to channel ch1
  • If you set ch1+ch2 on Rec Channel Select will input 1 goto ch1 and ch2. Input 2 will not be used.
  • Obvious, of course?
    Noah Kadner
    on Aug 5, 2015 at 8:12:04 pm
    I was referring to your channel configuration for the imported clips in FCPX's inspector.
    Noah
    Call Box Training
    Casimir Artmann
    on Aug 5, 2015 at 8:35:39 pm
    Sorry for not reply your message direct.
    Everything looks good as is should now.
    Thanx
    /Casi
