FCP 7 Frame blending in FCPX?
Mark Linthicum
on Jul 25, 2015 at 7:25:35 pm
Is there a way to get the old FCP 7 Frame blending in FCPX? It has nothing to do with slowing clips down, is just blended fames before and after into the current frame.
Thanks, Mark
Thanks, Mark
Noah Kadner
Re: FCP 7 Frame blending in FCPX?
on Jul 26, 2015 at 9:48:45 pm
Can you elaborate? Frame blending is a option used as part of retiming vs none or optical flow. All of which are options in the Retiming Editor. If you're looking for a kind of transition give more details.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Mark Linthicum
on Jul 27, 2015 at 5:59:58 pm
If you ever used FCP7 you would see that Frame blending option works differently that in the current version.
I went to After Effects for the effect. Wide Time in AE is the same as the old Frame blessing in FCP, i was just hoping it was built into the new FCP.
Thanks, Mark
Thanks, Mark
Jeff Kirkland
on Jul 27, 2015 at 9:02:52 pm
I'm not sitting in front of a computer I can check on but I'm fairly certain Motion has a wide time effect. If it does what you need, you could publish that as an effect back to FCPX.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
