Change default audio handle shape?
Martin Phillips
on Jul 22, 2015 at 12:27:53 pm
As the title suggests - 9 times out of 10 I want to use the linear fade to get a smooth transition between clips but haven't found a way of making it the default. Am I missing something or is this not an option?
Thanks - Martin.
Martin Phillips Freelance Cameraman / Producer / Editor
Chesham, Buckinghamshire, UK. http://www.thevideodepartment.co.uk
James Ewart
Re: Change default audio handle shape?
on Jul 24, 2015 at 6:17:18 am
Interesting question. I'm not sure how you can even tell what the default audio fade is when you apply a simple cross dissolve (picture and sound). I am guessing that because the default shape is +3db when you use the handles it must also be when you apply a transition like a dissolve
I think the difference between the four is subtle indeed and most of the time I find the default +3db audio fade works okay for me.
Larry Jordan seems to think so to in this tutorial from way back.
https://larryjordan.com/articles/a-better-way-to-do-audio-transitions-in-fc...
But of course your needs may differ.
Alex 4D has a sound only plugin which I think is what you are looking for
http://blog.alex4d.com/2011/07/11/fcpx-transition-sound-only/
http://www.jamesewart.co.uk
