iPhone 6 to FCP X ...change codec?
Michael Fiore
on Jul 6, 2015 at 1:34:42 am
When using footage shot from my iPhone 6 does the codec need to be changed like in FCP 7? It appears not but I want to double check.
Bret Williams
Re: iPhone 6 to FCP X ...change codec?
on Jul 6, 2015 at 4:22:20 pm
Not necessary. But if you're using a MacPro, new or old, you may have issues with performance unless you optimize to prores. It's just a checkbox on import or in your prefs and it happens in the background. You can continue working utilizing the original clip until the conversion has completed.
An iMac i7 (i5 too?) has a built in h264 hardware acceleration making single pass h264 export extremely fast and appears to assist on h264 playback in the timeline as well.
