How to disable automatic loading of recently used projects
Eric Brodeur
on Jul 3, 2015 at 6:06:22 pm
Using FCPX 10.2.1. When I open a Library, Final Cut starts opening recently used projects into my timeline.
Is there a way to turn this off?
I've looked around for an answer but only found solutions to the old system of Event management.
Mac OS X 10.5.7 / FCP 6.0.5 / QT 7.62
15" MacBook Pro 2.4 GHz / 4 GB / hard disks o'plenty
Kathy Murphy
Re: How to disable automatic loading of recently used projects
on Jul 3, 2015 at 6:59:53 pm
Close the finished project, then it won't show up.
Bret Williams
on Jul 3, 2015 at 7:04:24 pm
I don't think you can close s project. You can close a library, but once you open it it will load a project into the timeline. Seemingly randomly even.
Eric Brodeur
on Jul 13, 2015 at 10:08:49 pm
It does appear random. Yesterday it loaded the Library without opening any Projects.
David Gregorio
on Jul 3, 2015 at 7:03:32 pm
You can also hold option key while launching, this allows you to select a specific project or create a new empty library.
Also comes in handy if a corrupted library is crashing FCPX.
Tangier Clarke
on Jul 17, 2015 at 4:49:29 pm
I've noticed this as well that randomly FCP X will load a project that I am not working on or referencing. I've tried to find something consistent about this behavior, but I can't and it's annoying and time consuming.
You can hold option to force opening a particular library, but that still doesn't prevent the random loading of projects sometime.
Tangier
