Multicam audio handling - lacking fine tuning capability between tracks.
Sam Lee
on Jun 15, 2015 at 3:27:13 pm
Which method offers the greatest audio flexibility when it comes to be able to mute tracks when not needed with multicam? So far multicam is just too hard to be able to fade in and out on the individual audio tracks or mixing between the two. It is not easy to use ch1 from cam A and ch1 from cam B. It seems to be able to turn on or off completely and not be able to mute and mix between the tracks as easy as I expect.
Noah Kadner
Re: Multicam audio handling - lacking fine tuning capability between tracks.
on Jun 15, 2015 at 4:51:33 pm
You have access to all channels within Audio Components and can do all of the cross fades/volume leveling you might need up to a pretty specific level. Beyond that it's maybe time to finish in ProTools and Logic:
https://support.apple.com/kb/PH12579?locale=en_US
Noah
FCPWORKS - FCPX Workflow
Call Box Training
