Is there any way to extend the length of a keyworded section?
Noam Osband
on Jun 9, 2015 at 1:42:21 pm
I'm logging a ton of footage. Sometimes I keyword a section....and then realize i wish I'd extended what's keyworded by another couple seconds. It seems the only way to rectify this is to remove the keyword in the browser, reset ins and outs, add the same keywords again. Both in playing with the program and in looking online, there doesn't seem to be a way to extend the duration of what's keyworded. I can't change the "duration" tab or any other solution.
So....is there any way to play with the time - the ins, outs, and duration - of keywords you have already laid down?
Doug Metz
Re: Is there any way to extend the length of a keyworded section?
on Jun 9, 2015 at 4:51:10 pm
You don't need to remove the keyword first... but you're right. You need to reset your in/out points and apply the keyword again. You'll be left with extra instances of the keyword in that range, which you can safely delete in the keyword editor.
Doug Metz
Anode
