How can I find why Control-Cmnd-S, the theoretical shortcut for the saturation panel in color correction, has "System Reserved" next to it in the command editor?
Noam Osband
on Jun 6, 2015 at 6:02:17 pm
Today I discovered the keyboard shortcuts to go between the different panes in the color board. In theory, Cntrl Cmnd S should open the saturation panel. It doesn't work. I looked in the command editor and I see it says "System Reserved" I went to my Mac system preferences and looked all my keyboard shortcuts and I even spent time browsing online...but i can't figure out how to find what currently is holding Control Command S as a shortcut. Thoughts? How can I do that?
Craig Alan
Re: How can I find why Control-Cmnd-S, the theoretical shortcut for the saturation panel in color correction, has "System Reserved" next to it in the command editor?
on Jun 6, 2015 at 8:10:18 pm
https://support.apple.com/kb/PH18418?locale=en_US
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Neil Paisnel
on Jun 7, 2015 at 8:53:24 am
If I am reading correctlly, the OP has alresdy looked where that link suggests, SysPrefs, Keyboard , Shortcuts.
A link embedded within the page previously linked to,
https://support.apple.com/kb/PH18424?locale=en_US&viewlocale=en_US
Suggests any conflicts will apoear with Yello Exclamationmark
If that is not happening, then it sounds like a more deep routed cause.
I'd maybe try using that short cut combo, wirh FVPX closed. All apps closefd and see what happens.
Msybe the okd trick of creating a new user to see if it will work in FCPX when logged in as new user.
That might at least pin diwn the issue to 'System' or User
