Thumbnails disappearing; not rebuilding
Mike Bonner
on May 29, 2015 at 3:11:26 pm
I am having a really annoying problem in 10.2. Thumbnails in the browser will initially build, but when I scroll down to view additional clips, then scroll back (to clips previously with thumbnails), the thumbnails disappear. I can get them to "force" rebuild by trashing the cache and reopening the app. But, usually at some point I will lose the thumbnails again. Anyone else seeing this?
Noah Kadner
Re: Thumbnails disappearing; not rebuilding
on May 29, 2015 at 5:28:21 pm
I'd do a preferences reset and clear out renders.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Mike Bonner
on May 29, 2015 at 5:46:55 pm
Oh, I forgot to mention:
I deleted the cache, trashed preferences, and trashed plists.
I also see now that I have a few clips in a multicam clip that show up black, playback black, but audio is audible. Original clips play fine in the Finder.
Ugh.
Noah Kadner
on May 29, 2015 at 6:24:04 pm
I'd try deleting the FCPX app and redownloading from the App Store.
Noah
Call Box Training
Mike Bonner
on Jun 2, 2015 at 4:19:48 am
Very strange. Like I said, I had problems with disappearing thumbnails. I use two identical drives that I will work off of from work and at home, transferring the library whenever I make a change. The project at my work machine didn't experience any problems, but my portable drive gave me the problems I described. As a test I plugged my portable drive into my work computer, and low and behold, there were two clips that came up black. Checking the files in the finder, they played back fine. I tried reconnecting, deleting and replacing, trashing the cache, but each time they would come up black. Finally, I copied the event into a new library, and they were back. This is discouraging because I had a problem on a different project exporting, and it too was solved by creating a new library. So, libraries corrupting? But, this seems strange as I delete and replace the old library everyday just before going home.
Doug Metz
on Jun 2, 2015 at 4:31:36 pm
Hmmm... that is a bit strange. Two questions:
Are both drives formatted the same?
Are both drives ignoring ownership? Sometimes plugging in a drive to a different machine can cause this setting to become unchecked - not sure why.
Doug Metz
Anode
Mike Bonner
on Jun 2, 2015 at 5:16:27 pm
Yeah, both Mac Extended Journaled, both ignoring ownership.
I am reformatting the portable drive and repopulating. See if that helps.
Bernat Garrigos
on Jul 17, 2016 at 12:06:31 pm
Mike,
I have exactly the same problem. Did you finally solve it?
Joe Marler
on Jul 17, 2016 at 11:19:19 pm
I also had the same problem. In my case Spotlight indexing was disabled on the media drive. When I re-enabled this and allowed time for the indexes to rebuild, FCPX browser thumbnail generation became much faster on large events.
Disabling Spotlight on media drives is a common recommendation and maybe a good idea in some cases. However for very large events with thousands of clips, it appears Spotlight somehow accelerates thumbnail generation. I think it's ultimately a bug in FCPX since thumbnail generation would not just slow down, but would stop completely unless Spotlight was enabled.
There is still some initial lag on huge events (7000+ clips), and Activity Monitor indicates very high I/O rate (15,000 I/Os per sec on my 16TB RAID) but after they are generated it is very fast, even after selecting different thumbnail heights. If I select longer thumbnails (not just single frame) those must generate as I scroll down, but afterwards it remains fast -- even after rebooting.
Unfortunately there is no way to tell FCPX to proactively generate them -- you have to scroll down. The UI is somehow sending messages to the thumbnail generation thread. This is probably an optimization to avoid a lengthy thumbnail/preview generation period as with LightRoom, etc.
There may be multiple causes of this behavior. I first tried deleting the thumbnail files in the Library, which did not help. In my case it was unique to thumbnail mode in the Event Browser -- list mode never had any problem, and thumbnails always appeared in the timeline.
I have 7,000+ clips (many 4k H264) and over 4TB in one event on a top-spec 2015 iMac 27 and 16TB Thunderbay 4, and it works very well. It is amazingly fast after the thumbnails are generated.
