Two files from one
ed johnson
Two files from one
on May 22, 2015 at 11:50:54 pm
I have a two hour project all finished, and now I wish to make a twenty minute summary from it. What is the correct procedure to follow so that I do not lose my two hour version, but then I can also edit a copy.
TIA.
Ed.
Oliver Peters
Re: Two files from one
on May 23, 2015 at 12:23:30 am
[ed johnson] "What is the correct procedure to follow so that I do not lose my two hour version"
Right-click the project in the browser and select "Duplicate as Snapshot". This will create a copy without dependencies to the first project. You can freely edit each one without affecting the other. This command is analogous to "save a copy as" in other types of applications.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Bret Williams
on May 23, 2015 at 1:36:22 am
After effects should have this function. And if I've missed it, where is it?
ed johnson
on May 23, 2015 at 3:35:56 am
Boy, what would I do without this forum!
Thanks for saving me at least an hour and a whole bunch of stress!
