Reducing noise in an image
Mack McLaughlin
on May 22, 2015 at 3:21:08 pm
I have some super 8 footage that I am editing in FCPX and have a portion of the image that has a burn where the film was discolored as it went through the lamp. I ran an instance of Neat video, but it didn't reduce it because it is common to all frames.
Any ideas for removing this?
Noah Kadner
Re: Reducing noise in an image
on May 22, 2015 at 4:07:33 pm
You could probably reduce that a bit with a mask and some color grading. Or SliceX/TrackX. That said- looks like a particularly bad S8 transfer. Not sure how important this section is or whether it's possible to get it retransferred.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Mack McLaughlin
on May 22, 2015 at 4:50:01 pm
Thanks for the reply. It was actual damage to the tape, not the transfer. I will try some color grading and see if I can minimize it. Don't have a ton of experience with grading, so it will be a good learning experience.
Noah Kadner
on May 22, 2015 at 5:10:17 pm
Yep- you could do a lot with the Draw Mask tool in 10.2 combined with the color effect.
Noah
Call Box Training
John Fishback
on May 30, 2015 at 7:24:13 pm
If you use the color mask and choose the green with the eye dropper then you can either desaturate the color or change it to a different/better color.
