GPU and Video Editing Question
Leejay poichuk
on May 16, 2015 at 12:35:11 pm
Hi there,
I apologize if this is the wrong place for this post,
If so, please direct me to the proper section.
I am a video editor and recently I have been getting 5k footage to work with, I was working with FCPX and it was relatively slow to begin with, but after a few edits; superimpositions, fades ect the program would freeze up and cease to respond.
I thought if I upgraded to a computer with better ram/hd it might help my process. so thats what I did, what I didn't account for was the Graphics card. I'm not sure if this will make a major impact on my editing or not. but any help or advice you could give me would be greatly appreciated.
here are the specs.
Old Model:
Macbook pro. early 2011
2 GHz Intel Core i7
4 GB 1333 MHz DDR3
AMD Radeon HD 6490M 256MB
15.4 inch (14404 x 900)
500GB HD
New Model:
2 GHz Intel Core i7
16 GB 1333 MHz DDR3
Intel HD Graphics 3000 512 MB *
15.4-inch (1680 x 1050)
750GB HD
Noah Kadner
Re: GPU and Video Editing Question
on May 16, 2015 at 2:51:16 pm
Either of those cards will be slow in X. Try switching to proxy mode.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Leejay poichuk
on May 16, 2015 at 2:55:59 pm
How do you do that?
Lee
Noah Kadner
on May 16, 2015 at 5:14:08 pm
Google for "FCPX proxy mode."
Noah
Call Box Training
John Rofrano
on May 17, 2015 at 12:19:45 pm
[Leejay poichuk] "How do you do that?"
You can generate proxies when you import your clips. It's an option in the properties section on the right of the import window.
Since you already have clips in your project you want to:
  1. Select the clip you want to make a proxy for...
  2. Select the Info tab
  3. Press the Generate Proxy button
You can also select multiple clips and use File | Transcode Media and then in the window that appears, select the Create proxy media checkbox and click OK.
You can read more about it on Apple's support page:
Final Cut Pro X: Manage optimized and proxy media files
~jr
http://www.johnrofrano.com
http://www.vasst.com
