Keyword Collections
James Ewart
Keyword Collections
on May 12, 2015 at 7:31:20 am
Two odd things and not sure if it' me.
Occasionally I want to remove a keyword from a clip. I hit delete and it takes the other keywords as well even though only one is elected and command Z will not undo.
The other is that clip remains in the keyword collection even after I have deleted the associated keyword.
Am I being silly I wonder?
Doug Metz
Re: Keyword Collections
on May 12, 2015 at 4:28:16 pm
Select the clip you want to remove the keyword from, and open the Keyword HUD (cmd+K) - delete the keyword from there, and your clip will disappear from that collection while retaining your other keywords.
Doug Metz
Anode
James Ewart
on May 13, 2015 at 5:43:47 am
Thanks yes I've got that.
If I select the shot in the main event no problem but if I select the shot within a keyword collection it deletes everything but of course it is removing itself from the keyword collection. Should have figured that. I was thinking it was deleting all the keywords but in the main event they are still there.
Thanks.
Every now and then I still get a bout of confusedness.
