Anyone else having export problems in new version?
Mike Bonner
on May 12, 2015 at 4:38:46 am
Since updating, I have a project that results in a fail message when trying to render out to Apple devices (which I use to upload cuts for review). I can render out in other formats (such as ProRes), but when I do, there is no audio.
I've tried creating new projects, copying, pasting, deleting preferences, etc.
I've been traveling with an external drive between work and home (2013 iMac/ nMBP 6 core). Same problem on both machines.
A new bug, or just me?
Noah Kadner
Re: Anyone else having export problems in new version?
on May 12, 2015 at 4:47:40 am
I'd blow away renders- that often clears it up.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Mike Bonner
on May 12, 2015 at 4:57:11 pm
Update:
I removed FCPX and associated files, reinstalled, and was able to create new projects that exported normally, however, the project I was having trouble with still wasn't exporting. I tried copying event into a new library, as well as copying all clips into a new project. Same thing. I had success with exporting an XML of the project into a new library, it exported ok, but I got a long list of "frame boundary" warnings upon import of the xml.
Any ideas what that's about?
Jeremy Garchow
on May 12, 2015 at 5:05:36 pm
Corrupt media?
Mike Bonner
on May 12, 2015 at 6:30:42 pm
Corrupt Library?
The same media exported fine when a new project was created with an XML. Whatever the problem was, going through the XML solved it.
