Is there a keystroke to hop back 5 or 10 frames?
Noam Osband
on May 11, 2015 at 3:24:33 pm
I remember in 7, you could do Cmnd Spacebar to jump back 10 frames. I don't see anything like that in X and I've been searching lists of shortcuts. Am I wrong? Does this shortcut exist?
Jeremy Garchow
Re: Is there a keystroke to hop back 5 or 10 frames?
on May 11, 2015 at 3:48:00 pm
Shift arrow keys
Neil Paisnel
on May 12, 2015 at 12:16:55 pm
Shift works the same too with the nudge keys , .
Noam Osband
on Jun 15, 2015 at 11:40:29 pm
Is shift + arrow the most you can go back? Can you change it so the duration of frames you jump back is longer? I've been logging a lot in the browser and I'd love a way to keystroke more than a ten frame jump if possible.
Jeremy Garchow
on Jun 16, 2015 at 7:24:55 pm
[Noam Osband] "Is shift + arrow the most you can go back?"
How many do you need to go back?
Yes, "go back many" is limited to 10 frames at a time right now.
Eric Santiago
on Jun 17, 2015 at 12:55:31 pm
Back in the day I had my Kensington Mouse do all them weird commands.
Im not sure if you can still do that now.
Plus I havent owned a Kensington product in years.
