Multicam - lots of clips from same angle
Dan Rayner
on May 11, 2015 at 1:46:13 pm
Hi All
I'm trying to create a multicam timeline from a conference shoot. One angle was shot on an AF101 and so isn't limited to the 30 minute record time of the 5Diii that was shooting the second angle.
My question is this:
How do I create a multicam clip of the morning or afternoon session if one angle is one long clip (the AF101) and the second angle is spread over several clips (5Diii)?
Many thanks for any ideas.
Dan
Jeremy Garchow
Re: Multicam - lots of clips from same angle
on May 11, 2015 at 3:25:33 pm
Set the camera angles in the inspector (A for 101, B for 5D) and sync by angle and audio.
Jeremy
Dan Rayner
on May 11, 2015 at 5:31:18 pm
Many thanks Jeremy
Could you expand on that process a little please?
Dan
Jeremy Garchow
on May 11, 2015 at 7:26:31 pm
Select all the clips from the AF101.
Open the inspector and find the camera angle field.
Set the camera angle to "A".
Select all the clips from the 5D.
Set the camera angle to "B".
Select all the clips.
File > New > Multicam clip
Click "use Custom Settings" button.
Choose:
Angle Assembly > Camera Angle
Angle Clip Ordering > Automatic
Angle Synchronization> Automatic
Click "Use Audio for synchronization".
Click OK.
Mark Suszko
on May 11, 2015 at 7:36:09 pm
You'll have to use audio for the synchronization in his approach, unless you had the foresight to set all the cameras to time of day and free- running time code.
Dan Rayner
on May 11, 2015 at 8:06:48 pm
Great - thanks Jeremy.
