Double checking: am I right you cannot extend the length of a marker?
Noam Osband
on May 5, 2015 at 12:37:39 pm
I'm 99% sure this came out in the book I read from the library for FCP X. But I wanted to double check...if I make a marker, there is no way to have it extend for a certain length of time on a clip, correct? It only sits on the one moment where I put it. Just making sure.
Lawrence Eaton
Re: Double checking: am I right you cannot extend the length of a marker?
on May 5, 2015 at 1:47:49 pm
You are correct. I wish there was a way to define a selection with markers - similar to how chapters work.
Lawrence
Tim Jones
on May 5, 2015 at 4:12:55 pm
What about creating a marker at the start of your section named "My Section Start" and a marker at the end of your section named "My Section End"?
Markers are just a point in the timeline. Otherwise, they wouldn't be markers, they would be sections or chapters, etc...
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
Bret Williams
on May 6, 2015 at 2:00:08 am
FCP legacy markers were extendable.
Noam Osband
on May 6, 2015 at 1:02:16 pm
Indeed. I used that a lot. I'm learning to enjoy X but there are just certain things I dont get why you cant do, like that or resize all the windows however you want like you could in 7. Grrr.....
Tim Jones
on May 6, 2015 at 5:11:40 pm
Interesting - I use FCS 2 and never new that.
Tim
Tim Jones
Jeremy Garchow
on May 6, 2015 at 5:20:08 pm
What are you trying to mark? Perhaps a keyword or favorite will do the same thing for you?
Noam Osband
on May 6, 2015 at 7:12:47 pm
It would let me be able to put data on a clip and see the data from the timeline index. I want a way from, in the timeline, to know what I'm looking at. Ideally, I could make subclips and rename them. And I can't do that. So i was hoping I could extend markers. It seems kind of annoying that there is no good way to do that if you have a super long clip with many actions (or an interview) and you cant have a name that describes everything in it.
Jeremy Garchow
on May 7, 2015 at 1:38:19 am
Currently no way to do that with a range in the timeline AND have it show up in the index.
